Plug Wire Suggestions
Old Mar 20, 2003 | 04:50 PM
sbkim's Avatar
sbkim
Default Plug Wire Suggestions
I just installed TPIS headers. It sounds like most aftermarket plug wires touch the headers and end up melting. Are there any plug wires that have aluminum shielding or can accept factory shield to prevent melting?
Finally, what do you guys thinking about NGK TR55 Iridium plugs? I have copper now but tired of changing them once a year...
Thanks!!!!
Old Mar 20, 2003 | 05:01 PM
RskyBns's Avatar
RskyBns
Default Re: Plug Wire Suggestions (sbkim)
Thanks!!!!
I believe that the MSD's can use the factory shield (not 100% positive). Have the NGK Iridiums and they are a great plug. :yesnod:
Old Mar 20, 2003 | 05:10 PM
sbkim's Avatar
sbkim
Default Re: Plug Wire Suggestions (RskyBns)
Rsky,
Thanks! Did you get the TR55's? How often do you change iridium plugs?
Old Mar 20, 2003 | 05:33 PM
RskyBns's Avatar
RskyBns
Sbkim:
The plugs I have are the NGK-TR55IX plugs. They are great....and I'm comfortable changing them every 50k or more. Thunderracing.com has really good prices on them as well as wires.
Old Mar 20, 2003 | 05:44 PM
sbkim's Avatar
sbkim
Here are some discussions from the archive. sorry, I should have searched first. Looks like most are going with KoolSox as well..
http://forums.corvetteforum.com/zero...490854#4490854
Old Mar 20, 2003 | 05:59 PM
LoneStarFRC's Avatar
LoneStarFRC
:iagree:
The Magnecor KV 85's do accept the factory plug shields but you still might need the sox if the clearance is too close up higher on the wire.
Robert
Old Mar 20, 2003 | 06:09 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Default Re: Plug Wire Suggestions (LoneStarFRC)
Yup - got the Magnacors and use the stock shields, no problem.
Old Mar 20, 2003 | 06:49 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: Plug Wire Suggestions (BSiegPaint)
And the GM High Performance Wires can use the stock shields, obviously. Good bang for the buck!
Old Mar 20, 2003 | 07:15 PM
Toyride's Avatar
Toyride
Use NGK TR-55 copper plugs, no pucks, but you will have to change them sooner. You could also buy some cool sox to cover the wires.
[Modified by Toyride, 12:17 AM 3/21/2003]
Old Mar 20, 2003 | 07:46 PM
Waterfreak's Avatar
Waterfreak
Default Re: Plug Wire Suggestions (Toyride)
I can hook you up with a custom set of Phillip's Racing Wires with or without nomex shields. They accept the stock shields and come in blue, red, yellow, black or white. :cheers: These wires are used on many, many race cars. Alot of race engines come with some of the other after-market wires named and when they melt, the engine builders/crew chiefs switch to these race wires.
Old Mar 20, 2003 | 08:24 PM
YELLOHHH's Avatar
YELLOHHH
NGK Iridium plugs + Magnecor wires + Coolsox = :thumbs:
Old Mar 20, 2003 | 09:04 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
Thanks!!!!
yes they do fit RSKY! :thumbs: :lurk:
Old Mar 21, 2003 | 09:06 AM
sbkim's Avatar
sbkim
Default Re: Plug Wire Suggestions (devo)
Thank you all for the replies. Couple more questions:
1. Even with the factory shield, I noticed that one of the stock plug/shield is literally touching the headers. Is there any chance that the shield will get hot enough to melt the wire inside? I am not sure how to get around this other than beding the crap out of the wires... Please advise.
2. Where do you buy KoolSox?
Thanks!!!
To Plug Wire Suggestions
