SLP Headers Are On ....
Old Mar 21, 2003 | 03:28 PM
jeanlucpicard's Avatar
jeanlucpicard
Default SLP Headers Are On ....
Okay, I finally got these headers installed. It took 2-1/2 weeks of every night plus 2 weekends but I'm done. All but two days were spent on the passenger side header. The construction and fit of the headers is excellent. The installation is a daunting and laborious task that should be enlightened for others after I send T Byrne and SLP my installation photos and recommended revisions for installation.
I will know how well the headers perform next week as I'm too busy to run the car this weekend.
I have contacted Tom at T Byrne and Tracy at SLP and they have both expressed interest in my feedback so they can improve the installation process and instructions for others.
Briefly, you have a lot of tight wiring harness work and disassembly / reassembly work to do on the passenger side. The driver's side is fairly painless to do. Unfortunately, the SLP instructions do not adequately cover the actual tasks necessary for a 1st time SLP header installer - me for example. My notes and photos will also be posted to this FORUM in the Tech section next week for everyone's reference and use as needed.
On a final note, EVERYONE should look at their passenger side wiring harness feeding the starter and flywheel position sensor. Mine was stock OEM and all looming and wiring insulation on both harnesses burned through to the bare wire due to factory installation being up against the OEM exhaust manifold. If the flywheel sensor lead goes, you do not go! If the starter lead goes (3 wires) you will either stop dead or not have the ability to crank the starter. Do yourself a favor and check these harnesses - even on your stock car.
SAVE THE WAVE :seeya :cheers: :cool:
Old Mar 21, 2003 | 03:55 PM
Killrwheels's Avatar
Killrwheels
Default Re: SLP Headers Are On .... (jeanlucpicard)
Brings back memories....I had SLP headers on my Transam and they were a tight fit on passenger side. They would burn through wires weekly and nobody could repair them or align wires to keep out of the heat.
Finally Tracy stepped up to the plate and Jet Coated them for free, but I needed to pay for shipping and uninstall and install after coating. It worked, and the car ran great until sold. Kudos for Tracy and SLP, I believe they care and will use your advice ....
As for TBryne....well I will keep those thoughts to myself. :rolleyes:
Old Mar 21, 2003 | 06:18 PM
LoneStarFRC's Avatar
LoneStarFRC
Good "poop for the troops" regarding the wiring harness. PM's are WAY better than CM's. :yesnod:
Robert
Old Mar 21, 2003 | 07:23 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Re: SLP Headers Are On .... (LoneStarFRC)
:eek: :eek: Thanks for the heads up....that might be that burning smell I keep smelling (smells like burning plastic). :cheers:
Old Mar 22, 2003 | 06:44 PM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
Do they sound like this? :D
Old Mar 22, 2003 | 08:20 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
Here is to your stick to it attitude. :cheers: I had the TTS headers.
Passenger side was and is a total nightmare. I still have a dip stick tube leaking issue. :D
Old Mar 22, 2003 | 09:09 PM
Woodyman's Avatar
Woodyman
Great Job, but we need photos of your hands, I bet they took more abuse than the car and will probably remind you of that for a few days.
Woodyman
Old Mar 23, 2003 | 03:04 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
hard work . let see some dyno # :cheers:
Old Mar 23, 2003 | 10:55 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: SLP Headers Are On .... (stunna)
Glad you made it through.. :cheers: I installed a set once... never again :) :)
Old Mar 25, 2003 | 09:20 PM
RichS's Avatar
RichS
Default Re: SLP Headers Are On .... (CHRIS NJ C5)
I just started putting these on my buddys 2000. I have about 3 hrs in to it so far, and have both headers loosly bolted in. I have to unbolt the pass side though to move the heat wrap. They tell you to put it on the factory position sensor wires not the extention piece they give you. But after positioning the wires the extention piece it touching that wild rear tube. So far I don't tink they are too much harder than putting equal lenght headers on a 98 mustang cobra :D (not fun!) How good is the heat wrap they give you? I also made sure the extention piece is wired right unlike the one Chris got :eek:
Old Mar 25, 2003 | 10:34 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Guess I have a lot of work ahead of me. Just bought a set, I'll be installing in about two weeks. Hope my install goes a lot faster. :cheers:
Bob
Old Mar 25, 2003 | 10:59 PM
jeanlucpicard
Default Re: SLP Headers Are On .... (RichS)
Don't let the orange heat wrap sheilding that SLP provides touch the header or it will burn through. It is not heat resistant, only an insulator for protecting the wiring harnesses from the heat coming off the header now that the OEM heat shields are gone.
Old Mar 25, 2003 | 11:01 PM
jeanlucpicard
Default Re: SLP Headers Are On .... (16Again)
I can give you a lot of tips and photos that are not in the SLP instructions. The driver's side is a breeze. The passenger side is a MAJOR PITA :smash: :smash: because of all the wiring harness prep work you need to do.
Let me know if I can be of help. :thumbs:
Good luck.
Old Mar 25, 2003 | 11:07 PM
16Again's Avatar
16Again
Should be about two weeks before I find the time. Any tips or tricks are certainly appreciated. Thanks
Bob
[Modified by 16Again, 11:08 PM 3/25/2003]
To SLP Headers Are On ....
