Will the ENGINE Hold?
Old Mar 21, 2003 | 08:14 PM
Bad Bob's Avatar
Bad Bob
Default Will the ENGINE Hold?
OK I'm finally ready to commit to buying the h/c setup from Cartek, at first I couldn't afford the stage 2x package but have come into some money and I must have it. My question is with this package making between 450 and 472 hp as seen on the forum, will my engine hold together when I hit it with the TNT 150 shot. My car has 21k on it but the dealer went thru the motor completely last Aug. cuz I missed a shift and BOOM. Does anyone think this will get me into the tens with ET streets. Thanks, Bob
Old Mar 21, 2003 | 08:36 PM
XKR100's Avatar
XKR100
St. Jude Donor '08-'09
Default Re: Will the ENGINE Hold? (Bad Bob)
Why would you want to put a 150 shot on a motor that is already putting down monster numbers and take the chance of exploding it because of a possible lean out?Maybe I'm to old school because I don't get it!
Jerry
Old Mar 21, 2003 | 08:53 PM
Mitch C's Avatar
Mitch C
Default Re: Will the ENGINE Hold? (XKR100)
Jerry
:iagree:
I could not agree more, if you are making 470+RWHP if you are not already running the 10s you will be very close to it assuming good traction.
Bad Bob, BTW you have great looking car!!
Blackwing, Cartek Stage 2 Heads & Cartek M Cam, LS6 Intake, TPIS Headers, Underdrive pulley, Comp Puch rods, Rev 1116 Valve Springs,
Borla Exhaust, 172 t.stat, ST3500, 3.73 Gears, B&M Trans Cooler,
Hurst Line Lock, CCW Drag Setup
[Modified by Mitch C, 8:24 PM 3/21/2003]
Old Mar 21, 2003 | 10:59 PM
bparker's Avatar
bparker
If I were you I would ask Cartek that very question as no one has done more R&D than them - and could probably answer that best..
Have a good one :cheers:
Old Mar 22, 2003 | 12:42 AM
TEK WARRIOR's Avatar
TEK WARRIOR
You should run mid to low tens with a Cartek-X and 150 shot.They have X-packages in the tens now with no nitrous.Call Cartek and ask to talk to Julio about the nitrous set up,a lot has to do with tuning,Julio has his own timing retard system for a 150 shot,ask him about it.
To Will the ENGINE Hold?
