AC light blinking
Old Mar 24, 2003 | 03:54 PM
skidmarc's Avatar
skidmarc
Default AC light blinking
Whats wrong?????
Old Mar 24, 2003 | 08:42 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Re: AC light blinking (skidmarc)
Whats wrong?????
________________________________________ ________________________
My 98 coupe will do the same thing if I try to over ride the "auto" setting on the dual climate control. Now I just go right to "auto," and set the desired temperature. Let me know if there is a way to use just the "heat" without the AC coming on. I like to use the car without the roof, and would like to get some hot air on those cool N.Y. nights.
Old Mar 24, 2003 | 10:15 PM
texasredc8's Avatar
texasredc8
Is the temp reading below 40 degrees?? A/C comp won't come on. If you try to manually turn it on, it will blink and shut off.
You need to move down here to Houston, mine hardly ever blinks!! :D
Old Mar 25, 2003 | 09:53 AM
skidmarc's Avatar
skidmarc
Default Re: AC light blinking (TexasRedZ06)
thnks guys...I was hoping it was simple and not related to the ls6 intake I just self installed! I will investigate in warmer temp!
Old Mar 25, 2003 | 11:14 AM
JC in XTC5's Avatar
JC in XTC5
Also, whether in AUTO or MANUAL mode, if the airflow is directed to the windshield you cannot turn A/C off. Hitting the AC button will cause it to blink and stay on.
Old Mar 26, 2003 | 09:12 AM
skidmarc's Avatar
skidmarc
Default Re: AC light blinking (JC in XTC5)
thanks guys...I tried it yesterday in 50 degrees and it was fine...I had been concerned that my recent install of LS6 intake left ac hose crimped(seem to recall posts of that issue)....
To AC light blinking
