column lock fix
Old Mar 24, 2003 | 04:38 PM
Jim D's Avatar
Jim D
Default column lock fix
Since my 99 is on recall for the column lock problem, my dealer says they will fix it free. Does the GM fix take care of the problem, or do I need the bypass kit. Your experiences please, thanks Jim.
Old Mar 24, 2003 | 06:12 PM
zznotop's Avatar
zznotop
Default Re: column lock fix (Jim D)
Does anyone know if this affects 2003 models??
Old Mar 24, 2003 | 06:30 PM
JimJL's Avatar
JimJL
mine was recalled and fixed, seems like they did it right. it no longer locks when the car is off. :thumbs:
Old Mar 24, 2003 | 10:17 PM
texasredc8's Avatar
texasredc8
Default Re: column lock fix (zznotop)
2003s already have the "fix" installed at the factory. This however is still not a 100% guarantee that your's won't fail.
Old Mar 24, 2003 | 10:40 PM
Camarocks's Avatar
Camarocks
Default Re: column lock fix (TexasRedZ06)
What exactly is this column lock problem? I've noticed that a significant number of members here have it. Is there a recall on the car for this or is it just a TSB?
Old Mar 24, 2003 | 10:49 PM
bowtiebandit's Avatar
bowtiebandit
Default Re: column lock fix (Camarocks)
I've done about 100 of these and only had one come back with a bad relay. Basically what happens is the old mechanical lock was replaced with an electric version that doesn't al unlock when the relay is energizes thus rendering steering disabled. When the recall is done the automatics no longer use the feature but the manuals still have it with a little rewiring to the BCM and the redesigned ECL.
To column lock fix
