LT Headers...O2 Sensors/O2 Sims???
Old Mar 24, 2003 | 06:04 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default LT Headers...O2 Sensors/O2 Sims???
What's the scoop....if you're running LTs do you have to run sims in the back, can you run the actual sensors???
Someone fill me in, I'm getting header jitters :eek: :D
Old Mar 24, 2003 | 06:12 PM
70L46's Avatar
70L46
CF Pit Crew
Cruise-In I Veteran
Cruise-In II Veteran
Almost CI III Veteran
Cruise-In IV Veteran
Default Re: LT Headers...O2 Sensors/O2 Sims??? (Mean Green 2000)
The sims are only needed if you ditch the cats. The headers will have provisions for mounting the front sensors, the rear sensors will stay put if you are keeping your cats.
Old Mar 24, 2003 | 06:44 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: LT Headers...O2 Sensors/O2 Sims??? (70L46)
:cool: that explains it somewhat :D :cheers:
for the set I'm getting the stock cats get ditched but I am running hi-flow cats, so I assume there could be a provision, if so built, that accomodate the stock rear sensors, correct :)
Old Mar 24, 2003 | 06:49 PM
70L46's Avatar
70L46
CF Pit Crew
Cruise-In I Veteran
Yep, worst case you would need to get a couple of bungs welded into the pipes behind the cats to mount the sensors.
LT's high flow cats and Borlas - got your ear-plugs ordered :lol:
Old Mar 24, 2003 | 07:02 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
that's what I thought :D....thanks :D
:reddevil
Old Mar 24, 2003 | 07:37 PM
Wicked Zoh6's Avatar
Wicked Zoh6
If you have HighFlow cats, there is a chance that you will set an O2 code. I had it happen on a friends camaro with MAC headers/cats. Get the simms and not worry. :cheers:
Old Mar 24, 2003 | 07:39 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: LT Headers...O2 Sensors/O2 Sims??? (Wicked Zoh6)
I guess my underlying question is why would they set codes, with proper tuning....why are the sims necessary with a setup like this, :) :cheers:
Old Mar 24, 2003 | 08:02 PM
70L46's Avatar
70L46
CF Pit Crew
Cruise-In I Veteran
The rear sensors monitor the function of the cats by essentially monitoring their oxygen storage capacity. Since the PCM calibration is done for the characteristics of the stock cats, I could see where a different cat might throw a code. You should also be able to disable the rear sensors with LS1 Edit and not need the sims.
Old Mar 24, 2003 | 08:03 PM
Wicked Zoh6
Maybe High Flow cats flow too much :confused: Got me! All I know is that we put simms in and it was solved! :hurray:
Old Mar 24, 2003 | 08:04 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
wouldn't proper tuning utilizing the stock rear sensors also reduce throwing codes....just talking out loud :)
and thanks for the help, I really wanna do these headers once and the right way the 1st time :D
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
what headers :)
Old Mar 24, 2003 | 08:29 PM
Wt99C5's Avatar
Wt99C5
Mean, you only use one set of O2 sensors on the LGM's.
The collector is sooooo far back that you need to move the rear sensors forward and run sims in the rear.
Old Mar 24, 2003 | 08:31 PM
Z06 Quin's Avatar
Z06 Quin
I just installed the FLP's with the High flow cats. I haven't thrown any codes as of yet (about 1000 miles on them). According to MTI the rear O2 sensors only function is as mentioned above, and that is to monitor the performance of the cats....and that's it. Here in Texas the inspections are done via OBDII, looking for any emmisions problems. If the rear O2's are programmed out via LS1 edit then the PCM will fail inspection. Install the O2 simms and it will pass. I'm not sure what your requirements are in Tampa, but this is how it is here.
Old Mar 24, 2003 | 08:36 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: LT Headers...O2 Sensors/O2 Sims??? (Wt99C5)
no inspections currently but who knows when that could change and I really wanted to tone 'em down a little and not worry about the exhaust so smell, so I added the cats :)
I assume you mean you use the whole wire setup and hook 'em up to the front sensor input, otherwise the rears, which as stated will minitor the post cat pipes, will be monitoring and reporting the wrong values.
And isn't there anyone who can supply longer wires if that's all it takes to run rear sensors?....the wires for the sims have to be that long to work so why couldn't the sensors :) :cheers:
Old Mar 24, 2003 | 08:43 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The sims just plug into the wiring harness to trick the computer, they aren't physically connected to the exhaust, so no, they don't have to be long enough.
I have the sims, and one of them I think is NFG, as I constantly throw a rr 02 fault. I have the FLP's with the cats...I haven't been able to get the car on the lift since the install, I'm hoping I can just remove the sims and reconnect my rear 02 sensorss. The sims seem largely unreliable, as I've read tons of stories just like mine.
:cheers:
Old Mar 24, 2003 | 08:47 PM
Wt99C5's Avatar
Wt99C5
Actually there is only 1 bung per side. you will install what was the rear O2 sensors in the collector, which will be connected to the front O2 wiring harness. The wires that went to the rear O2's will be connected to the sims.
[Modified by Wt99C5, 1:49 AM 3/25/2003]
Old Mar 24, 2003 | 08:49 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: LT Headers...O2 Sensors/O2 Sims??? (Y2Kvert4me)
ahh, that makes sense :) :cheers:
:cheers:
so the FLPs have "bungs" to connect the sensors :)
To LT Headers...O2 Sensors/O2 Sims???
Old Mar 24, 2003 | 09:14 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Just used the sensors on my TPIS...no problems :D
Old Mar 24, 2003 | 09:35 PM
kp's Avatar
kp
I'm not sure what headers you are planning on using but the FLPs have the rear bungs after the cats and use the stock sensors just fine.
If you are planning on not using cats or if you have FLPs and you swap the cats off to race, simms or LS1 edit is a must. If you are running cats the rear O2s should work just fine. The reason some headers will still throw codes with cats is the cats are usually way further back then the stock cats and they just dont work as well as the stock setup. The only thing the rear O2s do is tell the PCM how well the cats are working :)
BTW, I run cats all he time and the rear O2s - never a problem..
[Modified by kp, 9:36 PM 3/24/2003]
Old Mar 24, 2003 | 09:39 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: LT Headers...O2 Sensors/O2 Sims??? (kp)
startin' to clear that muddy water :)...thanks kp :cheers:
