Check Engine Light HELP
Old Mar 25, 2003 | 02:11 PM
cgione's Avatar
cgione
Default Check Engine Light HELP
2-days ago just prior to shifting at about 5k rpm between 1st and 2nd my engine sputtered and the check engine light came on (FLASHING). :eek: After a couple seconds the engine began running smoothly and the light quit flashing. Has this happened to anyone and/ or does anyone know what the flashing engine light means :confused: :sad:
Old Mar 25, 2003 | 09:42 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Default Re: Check Engine Light HELP (cgione)
The PCM will flash The MIL (malfunction indicator lamp) if it detects a misfire condition which could damage the catalytic converter. The PCM may also have set a P0300 series code.
The sputtering you felt was likely a misfire caused by a bad plug, wire, injector, fuel pressure drop, PCM or ignition module fart. etc.
