PVC Mod HELP. Running into a Small Snag
However,
The small 2 inch piece of hose that remains after I pulled off the left side of the hose by the fuel rail cover and also the right hose near the throttle body is actually Attached to part of the car via a small black cable or something. I should be able to take this 2" piece out, BUT I CAN"T. :cuss It has what looks like a thick flexible metal electrical wire at the end that is attached to the car. The other end of this flexible metal wire is actually attached (built in) to the 2" piece of hose, and the hose is just sitting there suspended in the air and attached to part of the car via that darn support flexible cable/wire.
I haven't heard of anyone running into this?????? I want to remove the 2" piece of hose, but it is attached to part of the car and just sitting there in the way. I am not sure how to remove it or why no one else ran into this problem?
To better help with the location of the of this 2" piece of hose that I can't remove (or don't know how to remove), it is basically in the area of this picture where the blue part of the filter is, but it is attached via that flexible wire to a part of the car that is under where that filter is in the picture.
I know this is strange and my post confusing, but does anyone know what I am talkign about at all???
Thanks.....
:flag :flag :flag :D :D :flag :flag :flag :cheers:
[Modified by 2001 Red Coupe Bandit, 12:41 AM 3/26/2003]
Look at this:
If you're talking about the what I think you are, look at the 7 o'clock position and that little nut is what you can loosen to turn or remove.
[Modified by indypace78, 7:55 AM 3/26/2003]
To Be 100% Honest, this is soooo simple. I did this late last night and it was hard to see. I didn't see the plastic nipple connected to the end of the 2 inch hose, I was removing that hose and using the other nipple, :bb for lack of a better word.
Man just wait and do this stuff in the daylight, but sometimes you get so excited.
Thansk Indy, your always so helpful.
Gary
[Modified by 2001 Red Coupe Bandit, 8:24 AM 3/26/2003]
Hope this works.
IM me and I will give you my phone # if you still have questions.
I don't see any wire it could have been connected to. Maybe it connected to somewhere on my old LS1 manifold? :confused:
Thanks for the illistration though!
[Modified by Face, 5:07 PM 3/26/2003]
Thanks. It took me 5 minutes to do, Indy helped as well and I appreciate both of your pics. Maybe I will post a picture later tonight of my install and the 2 other mods I did, euro tail-lights and aluminum bezels.
You guys are so cool on the forum and very willing to help. I appreciate it greatly :cheers: :cheers:
Gary T :party:
Hope that helps. :)
[Modified by Bill Vett, 8:01 PM 3/26/2003]
There is a great website that shows this procedure in detail and here it is for all of you: http://benelliwang.badassride.com/Engine/index.html#PCV
Filter $12.99
3/8" Fuel hose $2.99
(2) 3/8 Inch Brass Fittings (the bolt part on these is 1/4") $1.25 each
About $16-$18, not too bad at all and looks cool as well.
Good Luck
[Modified by 2001 Red Coupe Bandit, 7:38 AM 3/27/2003]
I looped it so it would not kink.
If you had an angled NPT fitting or a right angle 3/8" piece of hose would work. Actually now that I think about it I have a swivel angled ntp fitting.
I just did it that way for simplicity and those were the parts I had on hand.
I will look into the other fitting this evening.
The Arrow on the filter "Points" toward the Right front passenger side tire.
I know it's kinda close to the engine, but I plan on ordering a metal can for it shortly.
The arrow should point toward the intake manifold.
