Traction Control Reprogram?
Old Mar 26, 2003 | 02:45 AM
blu00rdstr's Avatar
blu00rdstr
Default Traction Control Reprogram?
Is it possible to reprogram the traction control? It doesn't kick in soon enough, and it's too abrupt.
Punch it at 40mph, downshift-downshift, lose traction/fishtail, TC kicks in, bog, upshift-upshift, (still floored), downshift-downshift, lose traction/fishtail, TC kicks in, bog, upshift-upshift. Pretty entertaining for the other drivers.
Old Mar 26, 2003 | 07:34 AM
THRAP 42's Avatar
THRAP 42
Default Re: Traction Control Reprogram? (rd98rdstr)
Rd98rdstr,
According to the post below, seems the answer is yes. However, I'm presuming you don't have the active handling option and only have the TC on/off capability. If you have both AH/TC just put her in competition mode and all should be fine.
later,
[Modified by THRAP 42, 12:17 PM 3/26/2003]
Old Mar 26, 2003 | 12:41 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
It is possible with Ls1 edit. You can change the options on it.
Old Mar 30, 2003 | 08:36 PM
blu00rdstr's Avatar
blu00rdstr
Default Re: Traction Control Reprogram? (Wicked C5)
Thanks guys, LS1-edit sounds like it's one of those deferred purchase things I should buy sooner.
:flag :cheers:
Old Mar 30, 2003 | 11:13 PM
ScreaminDemon's Avatar
ScreaminDemon
How can you set your traction control to always be off on edit? I have edit, I just need the precedure?
Old Mar 31, 2003 | 12:49 AM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Traction Control Reprogram? (ScreaminDemon)
LS1 Edit may be able to set the control so the TC is off when you start the car but it can't change the TC programming.
Bill
Old Mar 31, 2003 | 12:57 AM
ScreaminDemon
Default Re: Traction Control Reprogram? (Bill Dearborn)
That's what I want, so I don't have to keep hitting that button. What is the precedure in edit?
To Traction Control Reprogram?
