W/N Start AGAIN!!!
Old Mar 26, 2003 | 05:15 PM
Rick-M's Avatar
Rick-M
Default W/N Start AGAIN!!!
It just happened again, 2nd time in two months. Went into store came out and nothing. The only thing that worked were the head lights and the remote lock/unlock and it would not chirp telling me the alarm was not setting. Called tow truck, hauled car to shop, unloaded car and “naturally” it started. The last time it took 2 days before it came back to life. Checked all the normal stuff grounds, battery etc.
HELP !
:banghead: :banghead: :banghead:
Old Mar 26, 2003 | 05:17 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: W/N Start AGAIN!!! (Rick-M)
This car has a lot of grounds within the electrical system. My guess would be that one of them is bad... :yesnod:
vetterdstr :cheers:
Old Mar 26, 2003 | 05:18 PM
Rick-M's Avatar
Rick-M
Default Re: W/N Start AGAIN!!! (vetterdstr)
That was my first guess also but checked and re checked all that, plan to do it again.
Old Mar 26, 2003 | 05:43 PM
vetterdstr's Avatar
vetterdstr
If you know somebody with a tech II,,, it would be easy to find with that...
vetterdstr :cheers:
Old Mar 26, 2003 | 06:14 PM
Rick-M's Avatar
Rick-M
no codes are being set.
Old Mar 26, 2003 | 10:30 PM
Gary2KC5's Avatar
Gary2KC5
Rick,
Have you changed anything lately, installed anything? hit a big bump, etc.?
I had a intermitent start problem, where the car always started but sometimes wouldn't run.
It turned out to be a ground.
Old Apr 4, 2003 | 11:24 AM
Rick-M's Avatar
Rick-M
Looks like the problem has been found. The fuse box under the passenger side leg area has a short. The panned was pulled out and when it’s moved around the “power failure” is duplicated. I’m not sure if it’s the panel, the connector or the harness, I will pull it apart this weekend.
If any one has any suggestions, comments or experiences please post them.
Old Apr 4, 2003 | 03:54 PM
C5BlkVette's Avatar
C5BlkVette
St. Jude Donor '03 thru '08,'16,'18,'21-'22,'24
Hopefully that's the problem!! Good luck!
Andy
To W/N Start AGAIN!!!
