Back up lights won't work!!
Old Mar 27, 2003 | 04:57 PM
robbber's Avatar
robbber
Default Back up lights won't work!!
Just seeing if anyone knew where the switch for back up lights were on 1997 C5?? THe lights work when I use the alarm, however, when put into Reverse, the lights do not come on?? Any help would be appreciated!!
Robbber :cheers:
Old Mar 27, 2003 | 07:35 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Default Re: Back up lights won't work!! (robbber)
RH side of the manual transmission for MN6, Park/Neutral Switch, LH side of the transmission for A4.
It could be the PERIMLP micro relay, located in the Underhood Electrical Center. This is a five-position relay. In normal operation, current flows through either the backup lamp switch or the Park Neutral switch, through the relay, to the backup lamps. When you use the remote to unlock the BCM energizes the relay to switch pole positions, allow current to flow through another position on the relay to the backup lamps.
Switch or wiring is more likely than the relay, but you never know.
[Modified by WhiteC5Vette, 6:51 PM 3/27/2003]
Old Mar 27, 2003 | 08:14 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: Back up lights won't work!! (WhiteC5Vette)
Mine has gone through three back up switches in 139,000 miles.
Old Mar 27, 2003 | 08:58 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Back up lights won't work!! (Fastguy)
I agree. Sounds like the switch itself. I went through a switch replacement during my first year.
Robert
Old Mar 27, 2003 | 09:16 PM
CCrane65's Avatar
CCrane65
I agree with the switch also. I had to have mine replaced on my '00 in the first year.
cc
To Back up lights won't work!!
