oil filter: UPF44 and PF44 the same?
Old Mar 30, 2003 | 05:36 PM
gaww's Avatar
gaww
Default oil filter: UPF44 and PF44 the same?
I went to Pep Boys to pick up an oil filter for my next oil change and did not see any UPF44's. I did buy the ACDelco PF44 oil filter. Are these two the same thing or do I specifically need a UPF. Also, how many quarts do I need. 6 or 7? How many miles do you guys go between oil changes? 3000 miles seems to be the norm, but then again this is super synthetic oil.
Old Mar 30, 2003 | 05:40 PM
wireless's Avatar
wireless
Photochop Terrorist
Default Re: oil filter: UPF44 and PF44 the same? (gaww)
3000 miles is too soon. Even the manual says so.
Old Mar 30, 2003 | 05:45 PM
ersatz928's Avatar
ersatz928
Default Re: oil filter: UPF44 and PF44 the same? (wireless)
The standard factory filter is the PF44. The UPF44 is a premium (better filtration ability) version. 3000 miles is fine, same as when I do it. Although a bit of overkill with synthetic oil, it wont hurt anything except your wallet (and the environment) to do it this often.
Old Mar 30, 2003 | 05:54 PM
shafman1's Avatar
shafman1
Default Re: oil filter: UPF44 and PF44 the same? (ersatz928)
I've read the UPF44 Filter (UPF meaning Ultra Perfomance Filter) is somewhat superior to the PF44, but either will work. :cheers:
Old Mar 30, 2003 | 08:45 PM
Oldvetter's Avatar
Oldvetter
Default Re: oil filter: UPF44 and PF44 the same? (shafman1)
I use UPF44 but PF44 are a good filter.
I go by my DIC to change oil, and I wait until it is low (under 5% oil life remaining), usually about 6,700 miles for me. Mine is a 1998, Chevy says to change at 10,000 miles or DIC.
Later years went to 15,000 miles. Some people with early years reset the DIC oil life at 50% oil life remaining. I don't since I have an extended warrenty.
Mobil 1 will support these extended oil intervals, get an oil analysis if you want to prove it to yourself. I know changing oil is an emotional issue but it doesn't have to be, there is science.
Oh, you will need 6.5 or 7 quarts. Some later years had wrong dip stick and full is halfway, so if you go to top of line it will use 7 quarts.
[Modified by Oldvetter, 8:47 PM 3/30/2003]
Old Mar 31, 2003 | 12:51 PM
Lil Red's Avatar
Lil Red
I didn't know that, good info! :hurray:
[Modified by Lil Red, 11:58 AM 3/31/2003]
To oil filter: UPF44 and PF44 the same?
