How Do You Replace A Thermostat?
Old Mar 31, 2003 | 05:25 PM
c5fvr's Avatar
c5fvr
Default How Do You Replace A Thermostat?
Hello once again I wanted to know if someone can help me with some very in detail instructions on how to take out the old thermostat and install a new one from start to finish. Thanks
Old Mar 31, 2003 | 09:34 PM
UtahVince's Avatar
UtahVince
Default Re: How Do You Replace A Thermostat? (c5fvr)
There's nothing to it. The thermostat is integral with the housing. Remove the radiator hose from the thermostat housing, remove the two 10mm bolts on the housing and install new thermostat housing. There's no gasket- it's O-ring sealed. You can catch and reuse the fluid if you want- or just refill, that's what I do.
Old Mar 31, 2003 | 10:40 PM
Toyride's Avatar
Toyride
Default Re: How Do You Replace A Thermostat? (UtahVince)
K.I.S.S. Theory KEEP IT SIMPLE STUPID
An excellent description and easy to follow. Even the mechanically challenged like mysef could do this.
Old Mar 31, 2003 | 11:08 PM
robsvette's Avatar
robsvette
Default Re: How Do You Replace A Thermostat? (Toyride)
its very easy. u will see for urself once u start.
To How Do You Replace A Thermostat?
