Real Powerloader info...No BS
Old Apr 1, 2003 | 11:08 PM
chuckster's Avatar
chuckster
Default Real Powerloader info...No BS
I actually opened it up tonight. After that April Fools post I got to thinking...
The removable Eprom is a Fairchild NM27C040V
http://www.fairchildsemi.com/pf/FM/FM27C040x120.html
Here is the link for the Specs on the chip and the programmer... Anyone know how to hack this?
http://www.elexp.com/tst_p848.htm
The Model 848 will program this Chip..
Old Apr 1, 2003 | 11:18 PM
2001 Red Coupe Bandit's Avatar
Default Re: Real Powerloader info...No BS (chuckster)
At a Boy Chuckie, making up for your deception.
:cheers:
Old Apr 1, 2003 | 11:22 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: Real Powerloader info...No BS (2001 Red Coupe Bandit)
:lurk:
Old Apr 1, 2003 | 11:28 PM
corvette184's Avatar
corvette184
Default Re: Real Powerloader info...No BS (MRWHOOPPEE)
:iagree: :iagree: :iagree: :iagree: :lurk:
Old Apr 1, 2003 | 11:34 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Real Powerloader info...No BS (corvette184)
Is it PLCC or DIP?
I have an eprom programmer that will work with it. (No BS, I use it with the chips for my LT1)
Eric
[Modified by 66ImpalaLT1, 9:35 PM 4/1/2003]
Old Apr 2, 2003 | 08:50 AM
chuckster's Avatar
chuckster
Default Re: Real Powerloader info...No BS (66ImpalaLT1)
Eric, its a PLCC for sure...
I know you have some "ELECTRONICS" Experience ;)
Old Apr 2, 2003 | 09:06 AM
chuckster's Avatar
chuckster
Eric I would be glad to send you the Chip and see if you can read it..
Also I wonder if it's erasable? There is no window on the front side..I wonder if the back has the window for UV Erase... :confused:
The rest of the Powerloader is all fully soldered surface mount components. Whick makes be believe even more that all that is need is the ability to write to that chip.
Old Apr 2, 2003 | 10:33 AM
Lil Red's Avatar
Lil Red
I would be willing to bet you are right! Worse case scenario, you get the information from the chip and use it as a template to program a new one. The chips are cheap, less than 6 bucks, you might be on to something. Keep us posted.....
[Modified by Lil Red, 9:35 AM 4/2/2003]
Old Apr 2, 2003 | 01:23 PM
BadAttitude's Avatar
BadAttitude
Chuckster,
In the DIP configuration it would have the UV window on the "top" of the chip, but the PLCC packaging places the UV window on the "bottom". Also, FWIW, the security of this chip is, well... security? :lol:
Not to put too fine a point on it, but with physical access to this chip, it's out bitch. ;)
I've got a loooong history of, umm, bit-banging (among other things) info from eeprom's people didn't want to be poked around in. I don't think whoever designed this PL device really had any major security concerns in mind. Which, could turn into a problem for them.
Ah well...
BadAttitude
Old Apr 2, 2003 | 01:43 PM
66ImpalaLT1
I'd be happy to read it for you, but I need to know if its DIP or PLCC. DIP is a rectangular chip with pins on two sides, PLCC is more square and has pins on 4 sides. If its DIP its probably a OTP, one time program.
I dont have the adapter to read/write PLCC on my programmer, but I'll look at getting the adapter I need.
I'd like to have it anyway, since I have a bunch of network cards I'd like to make PXE proms for that are PLCC :)
Old Apr 2, 2003 | 01:54 PM
chuckster's Avatar
chuckster
Eric, it's PLCC (Square)
Let me know I'd be happy to send it...
Also do you have LS1-Edit?
If so maybe you can compare the data from the Chip to the File I backed up from the PCM with the Powerloader code...
Old Apr 2, 2003 | 01:58 PM
chuckster's Avatar
chuckster
Default Re: Real Powerloader info...No BS (BadAttitude)
Chuckster,
Ah well...
BadAttitude
Bit Bang away!!! :smash: :smash:
The Powerloader was designed to write whatever is on the Chip to the PCM...
If we could put a stock flash on a chip an and get rid of the VIN# check...this could be a great use of old Powerloaders...
Old Apr 2, 2003 | 02:03 PM
66ImpalaLT1
Yes, I've got ls1edit.
Old Apr 2, 2003 | 02:08 PM
chuckster's Avatar
chuckster
Hmmm, maybe what started as a joke might just really happen in some way... :D :D
Old Apr 2, 2003 | 02:21 PM
BadAttitude
Check the data sheets. It's eprom, definitely NOT otp. You guys never know when you have a hacker in your midst. ;)
Old Apr 2, 2003 | 04:02 PM
chuckster's Avatar
chuckster
Ok you guys figure out the most qualified hacker here... :D
I'll supply the chip for you to borrow... ;)
Old Apr 2, 2003 | 10:25 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
I'd like to get my fan temp. changed on my loader.....jumping the gun, huh ?
To Real Powerloader info...No BS
Old Apr 2, 2003 | 10:46 PM
66ImpalaLT1
Yeah, I didnt look at the spec sheet too close.
If somebody else already has a PLCC eprom reader I'll let them tackle it. I need a $70 adapter to use PLCC chips in mine. (Not that I wouldnt like to have it)
Eric
Old Apr 3, 2003 | 01:38 PM
MTWallet's Avatar
MTWallet
I have a reader/programmer and UV eraser but I can only do DIP style. I will check and see if I can locate a PLCC adaptor for mine. I deal with programming these things all of the time, but not with the PLCC package.
Old Apr 3, 2003 | 01:55 PM
chuckster's Avatar
chuckster
Default Re: Real Powerloader info...No BS (MTWallet)
Yep, let us know... :smash: :smash:
We will find afterlife use for these Powerloaders after all.. :D
Even if all we do is a search for the Fan Temps and change them.. At least there is value in that alone.
who knows...Maybe at the least.. just edit the VIN# to the new owners car..
