Lowering Bolts Anyone Have Them?
Old Apr 3, 2003 | 07:35 AM
c5fvr's Avatar
c5fvr
Default Lowering Bolts Anyone Have Them?
Hey guys just want to find out for those of you who purchased the lowering bolts how much did it lower the front end and how hard are they to install??
Also where did you get them from ??
Old Apr 3, 2003 | 07:44 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Lowering Bolts Anyone Have Them? (c5fvr)
https://www.corvetteforum.com/techti...D=90&TopicID=1
Old Apr 3, 2003 | 07:45 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
https://www.corvetteforum.com/techti...D=27&TopicID=1
Old Apr 3, 2003 | 10:39 AM
99C5Richie's Avatar
99C5Richie
I got mine from West Coast Corvettes. More $ than others but I wanted the poly bushings that it came with... I didn't want to reuse the stock bushings. Check my sig for my ride height.
:cheers:
Old Apr 3, 2003 | 11:01 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Lowering Bolts Anyone Have Them? (99C5Richie)
Don't waste your money on the lowering kits vendors sell. :nono: They are a rip off. By some bolts at your local bolt supply store. :cheers:
Old Apr 3, 2003 | 11:46 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Default Re: Lowering Bolts Anyone Have Them? (racer44)
:iagree: , HOWEVER make sure that the bolts you buy are at least grade 5. Keep in mind, they're suspension components, so they have to be up to the task.
[Modified by leadfoot4, 11:47 AM 4/3/2003]
Old Apr 3, 2003 | 12:45 PM
JWilson's Avatar
JWilson
It is my understanding that the longer bolts are only for the rear. If you want to go lower in the front as you asked I belive the only way past the stock adjustment is to cut the bushing.
Good luck
JOHN
Old Apr 3, 2003 | 01:13 PM
MTWallet's Avatar
MTWallet
Default Re: Lowering Bolts Anyone Have Them? (JWilson)
Good luck
JOHN
This is correct for the front. Lowering bolts are just for the rear. Just find some 6" fine thread grade 8 bolts and you will be set. Call around to a few local supply houses, they should have them.
Racer's Avatar
St. Jude Donor '11
Good luck
JOHN
You are correct, I just assumed he meant for the rear. I guess never assume anything :nono: :D You can turn the front bolts and get maybe, if you are lucky, 1", if you want more you need to cut the front bushings. Look above and see the tips that meangreen linked for you. Also, I have this powerpoint that a fellow memebr did, you might want to follow it. http://www.members.shaw.ca/superchargedvette/Tips.htm :cheers:
Old Apr 3, 2003 | 04:30 PM
c5fvr's Avatar
c5fvr
Thanks for the help and the powerpoint presentation. I will be doing this hopefully in a week.
Old Apr 3, 2003 | 05:12 PM
msuc5vette's Avatar
msuc5vette
Does anyone else feel that the car doesn't ride as comfortably after lowering the rear?
I lowered mine in the rear to the point where only a thread or two remained showing, and I feel the ride quality has been sacrificed a noticable amount. On really bumpy roads the rear feels like it hops a little.
Just wondering if it is in my head, or if it is indeed worse than stock.
Old Apr 4, 2003 | 05:59 AM
leadfoot4's Avatar
leadfoot4
Default Re: Lowering Bolts Anyone Have Them? (msuc5vette)
msuc5, I felt that my ride got a little rougher than stock, however it isn't all that bad, and sure beats that 4x4 look!!
Old Apr 4, 2003 | 08:12 AM
Waterfreak's Avatar
Waterfreak
Default Re: Lowering Bolts Anyone Have Them? (leadfoot4)
I purchased the 6" bolts w/poly bushings for the rear from Ecklers. However, once installed, I noticed that at the highest setting, I didn't have proper rake from front to rear w/the fronts lowered with 2/3 bushings cut. I noticed that the poly bushings that came with the longer rear bolts were thinner than the stock bushings. So, I replaced the stock rear bolts but used the poly bushings instead of stock and now I have it lowered with a few threads showing on the stock bolt, w/poly bushings, and the height compared to the front is perfect. Also note that I have CCW 18' wheels all around and Bilstein sport shocks and hotchkis sway bars.
To Lowering Bolts Anyone Have Them?
