Clutch Problem
Old Apr 3, 2003 | 10:30 AM
BLMONGOOSE's Avatar
BLMONGOOSE
Default Clutch Problem
I just had my mechanic install me a new Mcleod dual disk clutch with a new master & slave cylinder.
The clutch pedal goes down smooth and the car runs normal but upon release the clutch pedal travels out slower than b4. I can literally remove my foot of the clutch pedal faster than it can come up. What is going on.
Is this normal due to the new master cylinder?
[Modified by BLMONGOOSE, 3:43 PM 4/3/2003]
Old Apr 3, 2003 | 11:11 AM
BLMONGOOSE's Avatar
BLMONGOOSE
Default Re: Clutch Problem (BLMONGOOSE)
TTT
Old Apr 3, 2003 | 01:11 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
No I do not believe that this is normal. I replaced mine with the Mcleod master and it does not behave that way. Check to see if the return spring is at the top of the pedal. I would take it back and have it checked.
To Clutch Problem
