heads/cam
Old Apr 4, 2003 | 11:10 AM
pdd000's Avatar
pdd000
Default heads/cam
im looking for a heads/cam package that will be streetable ,pass emissions in MA and be reliable. is there suck a package?? any suggestions out there? can i install them myself or does the engine have to be takin out of the car? :confused:
Old Apr 4, 2003 | 11:26 AM
pdd000's Avatar
pdd000
Default Re: heads/cam (pdd000)
or can i just buy a cam?
Old Apr 4, 2003 | 11:52 AM
C5B's Avatar
C5B
We need to know your desired results to give some advice. Like, how much HP gain? What you have already meets your requirements :jester
- C5B
[Modified by C5B, 5:08 PM 4/4/2003]
Old Apr 4, 2003 | 12:00 PM
Scott97's Avatar
Scott97
It all depends on how wild or mild you want to go.
Give Chris @ Speed Demon a call.
http://www.speeddemonmotorsports.com
Old Apr 4, 2003 | 12:07 PM
johnnyC5's Avatar
johnnyC5
Default Re: heads/cam (C5B)
also.... depends on how much you want to spend $$$$$
Old Apr 4, 2003 | 01:58 PM
NassyVette's Avatar
NassyVette
Default Re: heads/cam (johnnyC5)
Call up any tuner MMS, ARE, Cartek etc. and tell them what you want. How streetable it is will be determined by your cam size. But typically the bigger the cam is, the more power you get.
Old Apr 4, 2003 | 06:28 PM
pdd000's Avatar
pdd000
id like to be at around 400rwhp, but if i cant get it reliable or pass emissions then ill settle for less. for money wise id like to stay around 2k or less :cheers:
Old Apr 4, 2003 | 06:37 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Our G5 heads/cam package with our headers will get about 420RWHP and has passed Texas emmissions. Give us a call at 972.272.7753 for a quote and for more specifics.
Old Apr 4, 2003 | 06:40 PM
XCELER8's Avatar
XCELER8
Default Re: heads/cam (Godspeed)
Arent the headers alone almost $1500 plus install?
Jon
Old Apr 4, 2003 | 06:43 PM
Godspeed's Avatar
Godspeed
Senior Member
Default Re: heads/cam (XCELER8)
Hi John, the stainless steel long tube system is 1995.00 and is complete all the way to the catback ready to bolt right up.
Old Apr 4, 2003 | 07:00 PM
pdd000's Avatar
pdd000
I the flp long tubes already :yesnod:
Jon
Old Apr 4, 2003 | 08:54 PM
SideStep's Avatar
SideStep
What??? :confused:
Old Apr 5, 2003 | 03:39 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: heads/cam (SideStep)
He meant he has the FLPs already.
I would find a tuner close to you that can do the mods, that way if there is a problem you wouldn't have to send the car across the country to get it fixed. Just my opinion.
Old Apr 5, 2003 | 03:47 PM
Phil97SVT's Avatar
Phil97SVT
I would go with the following:
Total Engine Airflow S1.5 heads 11.0:1 Cr
Comp Cams 222/226 114lsa 110icl
LS6 intake
TPIS long tubes
Dr gas x pipe
ASP underdrive pulley
It will make awesome power and be a blast on the street, should pass emissions as long as you have cats.
Phillip
Old Apr 5, 2003 | 10:24 PM
XCELER8's Avatar
XCELER8
Default Re: heads/cam (Phil97SVT)
LS6 intake
TPIS long tubes
x pipe
Phillip
What rwhp would that be capable of if tuned perfectly?
I have all those pieces except my cam is a Comp 224/224 .581lift and 113lb & I have no cats, larger MAF, and blackwing
My heads are same 11.0:1CR just curious before I take it upto Orlando.
Jon
Old Apr 5, 2003 | 10:29 PM
ITSovr4U's Avatar
ITSovr4U
see sig :seeya
To heads/cam
