Ring And Pinion
Old Apr 5, 2003 | 08:51 PM
TheBigDog's Avatar
TheBigDog
Default Ring And Pinion
My 02 vette is an A4 with a 2:73 rear end. Can a ring and pinion gears be purchased and convert rather than purchase the whole rear end? I have been reading some CF members are changing gears only. Who can do it and what is the approx cost?
Old Apr 5, 2003 | 09:02 PM
brrymnvette's Avatar
brrymnvette
Default Re: Ring And Pinion (TheBigDog)
It has to be a 3:15 or numerically higher carrier. That is what I was told. Hope this helps.
Old Apr 5, 2003 | 10:10 PM
Mitch C's Avatar
Mitch C
Default Re: Ring And Pinion (brrymnvette)
:iagree:
Old Apr 5, 2003 | 10:43 PM
clancy's Avatar
clancy
Default Re: Ring And Pinion (Mitch C)
:iagree:
For the price of the entire assembly your better off getting the entire rear end, assuming its the 3.42 gear. The 3.73 is at least double the price of the 3.42's,but your 2.73's are not able to accept the 3.42 or 3.73 ring & pinion gear, changing the gears is definitly worth it :) Good luck
Old Apr 6, 2003 | 07:24 PM
JCR's Avatar
JCR
The 2.73 rear carrier is the same for all of them. The differential has to be replaced to accomodate the new ring and pinion however. If you have a 3.15 or higher differential then you could go to a higher gear ratio without replacing the differential. The 2.73 uses a very unique differential . A great rear for economy highway driving though. You would have to shop around and see what a new diff. costs for performance setups (3.15 higher).
To Ring And Pinion
