Help! Stuck again with Ripper Install!
Old Apr 6, 2003 | 07:20 PM
ColoradoSilver's Avatar
ColoradoSilver
Default Help! Stuck again with Ripper Install!
Hey all, thanks for your help with my last question, but now I'm stuck again. I'm installing this B&M and I've removed the 4 bolts holding down the shifter. The next step says to remove the shifter assembly from the shifter housing. How is this done? The thing seems to be in there pretty solid and won't budge. Please Help!! I'm so fristrated! Thanks for your support,
Matt
:mad :mad :mad :mad :mad
:flag
Old Apr 6, 2003 | 07:34 PM
Harris's Avatar
Harris
Default Re: Help! Stuck again with Ripper Install! (ColoradoSilver)
Gasket may be stuck a little. Gently pry up on the shifter flange between it and the housing it should loosen so you can lift the shifter out.
Old Apr 6, 2003 | 07:38 PM
GraveDigger's Avatar
GraveDigger
If all bolts are out pry with a screw driver. It gets hot down there and can fuse together.
Maineiac's Avatar
Maineiac
From: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Default Re: Help! Stuck again with Ripper Install! (Harris)
:withstupid:
Old Apr 6, 2003 | 09:45 PM
ColoradoSilver
Install done!! Thanks for all your help guys. Everything works great!! :D :D :D :D :D :D :D :seeya :seeya :seeya :thumbs: :thumbs: :thumbs: :party:
To Help! Stuck again with Ripper Install!
