Shifter option
Old Apr 7, 2003 | 03:06 AM
SpinMonster's Avatar
SpinMonster
Default Shifter option
After wanting a short throw shifter, I ended up getting a kirban because I liked the accuracy of the shifts but not that the throw is only about 20% shorter. My brother and I looked at it and came up with a kewl idea.
We machined off the forward corner of the bottom of the separate upper section of the shifter(it comes in two pieces)(if you don't do this the car wont go in reverse without a fight), cut off 5 of the **** threads, and drilled a new hole above the top hole on the same section. We then attached the center section using the original top hole as the bottom and the newly drilled top hole as the new top. (use a smaller diameter bolt and nut as the shifter is thinner near the top so you retain it's strength. The resulting shifter is about half the throw with the acurracy of the kirban.
I'll try to post pics if I can figure out how to post them....newbie.
Hope someone benefits.
Old Apr 7, 2003 | 03:11 AM
MyFirst's Avatar
MyFirst
Default Re: Shifter option (SpinMonster)
Innovation is the mother of all invention. Nice job.
Old Apr 7, 2003 | 03:46 PM
SpinMonster
ttt
Old Apr 7, 2003 | 04:15 PM
CR555's Avatar
CR555
PICS, WE WANT PICS!!! If you want any response, you will need to show pics. That's one of the unwritten rules on this Forum! :D
I've send you an IM with a link to a picture host. Just sign in, it won't cost you anything. Just make sure you shoot the pics with highest compression, so they don't consume too much webspace!
Old Apr 7, 2003 | 05:00 PM
pewt2k's Avatar
pewt2k
If you want, e-mail me the pics & I'll put them online for you.
To Shifter option
