Pass. Window rattle inside door panel
Old Apr 7, 2003 | 03:02 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Pass. Window rattle inside door panel
When I shake it, man it rattle really loud. It's quite on the driver side.
What could it be?
Just open the panel last nite and will need to remove Dynamat : :mad so just wanna ask experts here so I can have a better look.
:cheers:
Old Apr 7, 2003 | 04:19 PM
EWill3rd's Avatar
EWill3rd
Default Re: Pass. Window rattle inside door panel (mike76002)
On the rear section of the regulator look down towards the bottom.
There is a 13mm nut holding a stud in the door, that stud controls the in-out adjustment for the top of the glass, most often I find the regulator has come off of the stud, this causes the regulator to flop around if the window is down at all.
Just loosen the nut and thread the stud back into the regulator using an alan wrench. Don't turn it in too far or you will screw up the glass adjustment.
Then tighten the nut, close the door and make sure the fit is good.
Seen it lots of times.
EWill
Old Apr 7, 2003 | 06:09 PM
0Vette Stripes
Former Vendor
Default Re: Pass. Window rattle inside door panel (EWill3rd)
Thanks :cheers:
To Pass. Window rattle inside door panel
