head gasket %$#@
Old Apr 8, 2003 | 09:45 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default head gasket %$#@
Pulling in my driveway (fortunately) and before I could shut down I heard a loud clattering like a rod knocking and though the car will still idle it has no power so I assume I've blown a head gasket f%$#, I havn't even had time to run the car hard, another advantage of having a blower I guess, fortunately my 436ci "NA" will be here in a couple of weeks. Here's to cometic head gaskets :U and :thumbs: (upps wrong finger)
Old Apr 8, 2003 | 09:55 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: head gasket %$#@ (NEPTUNEBILL)
Sorry to hear about the old motor. The NEW motor leaves me with inches/hp/tq envy!
:lol: :lol: :lol: :thumbs: :cheers:
Old Apr 8, 2003 | 09:58 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: head gasket %$#@ (binksZ06)
What kind of head gaskets did you use?
Old Apr 8, 2003 | 10:01 PM
NEPTUNEBILL
Theres probably not 4000 miles on this motor and it has rarely seen boost for very brief periods of time, I have heard that this is not uncommon with the cometic's wish I had heard that sooner, Now my car will have to sit for a the next month while we drop in the new motor I'm sure not going to spend a bunch of coin to put the gasket in just to drive for an extra couple of weeks. Thanks for the vote of symphathy however---bill
Old Apr 8, 2003 | 11:50 PM
MrEracer's Avatar
MrEracer
Bill,
You need to at least confirm that no coolant is getting into the cylinders... If you let it sit with coolant in the cylinders it will be rusted solid in less than a week. Take the spark plugs out and give it a compression check to confirm your diagnosis and check for water... BTW, replacing a head gasket is not all that difficult... Get to work man, and fix it. :D
Shirl
Old Apr 9, 2003 | 12:49 AM
NEPTUNEBILL
Default Re: head gasket %$#@ (MrEracer)
Thanks Shirl, I'm affraid thats what I'm going to have to do as if I'm not busy enough, but you're right I can't let it sit if coolant is getting in, even though my block is going back for a core and will be resleaved I don't think Wade would appreciate having to open it up with a cutting torch :lolg:
Old Apr 9, 2003 | 03:14 AM
Dax73gt's Avatar
Dax73gt
I have went through lots of cussing about head gaskets on normaly asperated 11 and 12 to 1 ls-1 / 6 engines and now I think that with ARP studs a little ACE Hardware silicone might keep things sealed. ie: don't blame it just on the gasket. :skep:
Old Apr 9, 2003 | 03:22 AM
C5B's Avatar
C5B
Default Re: head gasket %$#@ (Dax73gt)
What are you suggesting the sillycone be used on? I am going to install my heads in few weeks, and will be using ARP head studs (already in hand).
My compression ratio is only going to be 10.6:1 and I am using the stock GM head gaskets.
Thanks!
- C5B
Old Apr 9, 2003 | 01:08 PM
NEPTUNEBILL
Well, actually I owe Cometic an appology at this point, I checked compression and it was s@#$ on #8 but no signs of coolant in the cylinder or leaking anywhere and the compression in the other 3 was fine. This leaves piston, rings or valve spring so I pulled the valve cover and low and behold the exhaust valve spring is broken enough for the end to slip out from under the retainer. I am borrowing a compressor and spring tool and will see if the valve seals with the compressed air :blueangel: if so a new spring and I should be back on the road. The spring is still substantial enough in place where I doubt it hit the piston :blueangel: as you can see I threw several prayers in there. I just need this thing to run well for another 3 weeks or so till the new motor is dropped in.===Thanks for the support---Bill
To head gasket %$#@
