transmission fluid
Old Apr 9, 2003 | 04:09 PM
Kal-El's Avatar
Kal-El
Default transmission fluid
I have about 50k miles on my transmission. Is it a good idea to change transmission fluid? And if so, how do you do it?
Old Apr 9, 2003 | 04:48 PM
Jochen's Avatar
Jochen
Default Re: transmission fluid (Kal-El)
Hey Hal El,
i suggest you should use the "search" function. This topic has been discussed many many times here, and there were some pretty good links and explanations on how to do.
I did this job a few weeks ago. Pretty simple and straight forward. One hint: use an oil pump (electro or manual) to pump the oil into the tranny. This will save you a lot of dissorder under the car.
Jochen
Old Apr 9, 2003 | 05:26 PM
gmblack3's Avatar
gmblack3
Default Re: transmission fluid (Jochen)
http://www.woosch.com/tranny_diff_fluid_change.htm
To transmission fluid
