Replacing manual door lock and unlock switch?
Old Apr 11, 2003 | 09:23 PM
Vinzvette's Avatar
Vinzvette
Default Replacing manual door lock and unlock switch?
On the door my lock switch I believe is out, Anyone know what a switch costs and do I just lift up the rubber part and install a new one?
Old Apr 11, 2003 | 11:22 PM
EWill3rd's Avatar
EWill3rd
Default Re: Replacing manual door lock and unlock switch? (Vinzvette)
Do you mean the power lock switch assembly?
Sounds like you might mean the manual switch that is part of the door handle.
If you mean the power lock switch, the whole panel is serviced as a unit.
You lift up on the rear of the switch with a small flat bladed tool, lift the switch out, unplug it and replace it with a new one.
Why do you think it's bad?
There is a computer in there too, the switch is just an input to the computer.
Tell us your symptoms.
EWill
Old Apr 13, 2003 | 10:53 AM
Jack Behrle's Avatar
Jack Behrle
Default Re: Replacing manual door lock and unlock switch? (EWill3rd)
I also have a right door that I cannot lock/unlock with:
--the key fob
--the key
--interior lock/unlock switch on drivers door
Any suggestions? The lock tab on the right door moves somewhat to the unlock command from the drivers door but not full stroke enough to actually unlock.
I am worried that should I suffer the same failure on drivers door I will truly be locked out of car! I am told there is a module in both doors that controls this function. (No codes)
Any ideas anyone??????????
Jack
Old Apr 13, 2003 | 01:22 PM
EWill3rd's Avatar
EWill3rd
Default Re: Replacing manual door lock and unlock switch? (Jack Behrle)
Sounds like a weak door lock actuator.
If the lever moves slightly with an unlock press on the drivers control, the signal is getting to the PDM/RDCM (Passenger Door Module/Right Door Control Module) and the module is trying to operate the actuator.
It's quite likely a failing actuator.
Especially if the window works okay.
EWill
[Modified by EWill3rd, 6:24 PM 4/13/2003]
To Replacing manual door lock and unlock switch?
