True hardcore brake math.
Old Apr 14, 2003 | 02:01 PM
J-Rod's Avatar
J-Rod
Default True hardcore brake math.
Have you ever wondered what would happen when you upgrade your fronts, or swap M/C, or any of the other things you can do to a braking system. Well, your braking system is just hat, a complete system. So rather than do somehting for looks, or that may in fact make your car brake worse.
Here is a spreadsheet that will help you calculate all your brake variables.
http://users3.ev1.net/~black_ops/z06.../brakemath.xls
Disclaimer: Don't hurt yourself with this. A couple of bad keystrokes could cost thousands.... Don't ask. :)
Big disclaimer: If you use this spreadsheet to design your brakes and they fail horribly and you die in a fiery crash… It's not my fault. YOU are responsible for verifying the accuracy of this information. I am not a Professional Engineer… There may be many errors.
[Modified by J-Rod, 2:01 PM 4/14/2003]
Old Apr 14, 2003 | 03:32 PM
YELLOHHH's Avatar
YELLOHHH
Default Re: True hardcore brake math. (J-Rod)
Not that bad, really. It doesn't include the rest of the story in brake design. Ventilation factors , finite element structural analysis of the caliper to prevent noisy brakes, acceptable unsprung weight. wheel/caliper clearance. brake booster design. variable contact patch (e.g., bmw is using fast deflation/inflation for future enhanced braking performance of its x5). aerodynamic loads (obviously worse is better).
Greg
:steering:
Old Apr 14, 2003 | 10:35 PM
davidfarmer's Avatar
davidfarmer
Default Re: True hardcore brake math. (YELLOHHH)
This is what stoptech has been pushing for years. Improper piston sizing hurts braking performance, not help!
Old Apr 15, 2003 | 01:31 AM
C5stein's Avatar
0C5stein
Former Vendor
J-Rod
Very Nice! :thumbs:
To True hardcore brake math.
