Column Lock Help Needed
Old Apr 14, 2003 | 07:09 PM
Wicked Whitey's Avatar
Wicked Whitey
Default Column Lock Help Needed
Went to the garage to take the Vette out and the Service Column Lock warning came up on the DIC.
The wheel is locked....now what do I do???
W W
Old Apr 14, 2003 | 07:27 PM
Dale RED 98's Avatar
Dale RED 98
Default Re: Column Lock Help Needed (Wicked Whitey)
Try here! https://www.corvetteforum.com/techti...=105&TopicID=1
Old Apr 14, 2003 | 08:43 PM
sunvet's Avatar
sunvet
I had this happen to me one night after a meeting. A friend took me home (hated to leave my baby outside overnight!). The next day, I put the key in and the column unlocked immediately. I drove straight to the dealer where I bought the car ('00 vert). When I picked it up, they said there was no problem, no codes, so they didn't do anything!
It happened once again, same kind of deal about unlocking after a period of time. Back in the garage, and I didn't drive the car until I installed the CL bypass. The CL failed again during the install procedure. I was finally lucky that the CL unlocked with the ignition on, and at that time I just unplugged the cable from the CL. When I turned off the key, the CL couldn't close since the cable was unplugged.
After installing the bypass, I got the Service Column Lock display on the DIC. So I finally unplugged the battery, waited awhile, and then reconnected. I'm glad I put the bypass in, it's not worth taking a risk of being stranded again.
-Jim
:cheers:
To Column Lock Help Needed
