Rough Idle
Old Apr 14, 2003 | 08:06 PM
Chris98's Avatar
Chris98
6th Gear
Default Rough Idle
I have a 98 6 speed with 50K miles. When it reaches operating temp, it has a noticably rough idle. I just replaced the stock plugs and wires with Taylor Thundervolt wires and Delco platnium plugs. The idle is exactly the same. I burn BP 93 octane and I have run a couple bottles of injector cleaner through it. Any ideas?
Thanks!
Old Apr 14, 2003 | 09:02 PM
edmaverik's Avatar
edmaverik
Default Re: Rough Idle (Chris98)
Sounds like your MAF sensor is gooped up. Have you considered cleaning it? What kind of air intake?
Old Apr 14, 2003 | 09:05 PM
Chris98's Avatar
Chris98
6th Gear
Default Re: Rough Idle (edmaverik)
I didn't know you could clean them. Have you ever done it? It has stock air intake.
thanks a lot!
Old Apr 14, 2003 | 09:09 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Check for air leaks, vacuum hoses not completely installed on TB or MAT sensor not plugged into air coupler.
Look for cracks in your intake setup.
Just some ideas.
Old Apr 14, 2003 | 09:55 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Rough Idle (chucschramm)
chucshramm - Beautiful pic of your ride on the beach! Looks awesome. :yesnod: :yesnod: :yesnod: :thumbs: :cheers:
Sorry,I realize this is off topic but.........
joel
To Rough Idle
