hotchkis
Old Apr 16, 2003 | 02:04 AM
pdd000's Avatar
pdd000
Default hotchkis
hotchkis bars make a clankin noise when i hit a bump, is that normal :confused:
Old Apr 16, 2003 | 02:19 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: hotchkis (pdd000)
You need to torque the end links more. I torqued the living hell out of mine and not one peep for over a year now.
Old Apr 16, 2003 | 10:27 AM
Jeff Jeff's Avatar
Jeff Jeff
Default Re: hotchkis (C5-VERT)
Torque them to spec in slow fluid motions, several times on each bolt. The way the locknuts are, if you torque too fast, you will get incorrect torque readings.
When I installed mine, they started "clunking" after a week. I pulled the wheels and retorqued -- haven't made a noise in over a year.
Old Apr 16, 2003 | 10:56 AM
C5stein's Avatar
0C5stein
Former Vendor
Default Re: hotchkis (Jeff Jeff)
:iagree:
These guys are both right. It happens when switching to GM metal end links too. If you don't get them tight enough, they will creek like mad.
We don't like the type of locking nuts that they use as they make it harder to torque as well as make it harder to remove when we need to disconnect end links to adjust corner weights or bar pre-load. We replace them with Nyloc nuts, which are easier to tighten and to remove, but stay torqued.
Old Apr 16, 2003 | 04:47 PM
TTRotary's Avatar
TTRotary
Default Re: hotchkis (C5stein)
Mark, could you provide the specs on the substitute locknuts for the hotchkis? I am assuming 5/8 fine thread, grade 8 nylock, but just wanted to be sure. Also, what torquesspec would I use on the Nylock? I don't even recall seeing a torque spec with my hotchkis bars. Thanks - MTS
PS - I f you don't have all this no problem. I'll find it instead of being lazy. :D :D
[Modified by TTRotary, 5:51 PM 4/16/2003]
Old Apr 16, 2003 | 05:49 PM
pdd000's Avatar
pdd000
what are the torque specs for the hotckis :confused: thanks for the info guys ;)
Old Apr 16, 2003 | 06:45 PM
jmX's Avatar
jmX
The GM torque specs are on my page. They will be the same irreguardless of which bar you use.
http://www.ls1howto.com/index.php?article=16
Old Apr 16, 2003 | 09:04 PM
C5stein's Avatar
0C5stein
Former Vendor
Default Re: hotchkis (jmX)
jmX - That is a nice web page! :thumbs:
Old Apr 16, 2003 | 09:10 PM
C5stein's Avatar
0C5stein
Former Vendor
Default Re: hotchkis (TTRotary)
TTRotary
The nyloc nuts are either 5/8 - 20 or 1/2 - 20 and grade 5 or grade 8 is not critical in this situation. I can't recal the size as it has been almost one week since I did my last one.
I think we torque them to about 55 foot lbs. There isn't a torque spec in the instructions.
Old Apr 16, 2003 | 10:50 PM
pdd000's Avatar
pdd000
:iagree: :iagree: thanks :thumbs:
Old Apr 17, 2003 | 12:54 PM
TTRotary's Avatar
TTRotary
Thanks Mark. :)
Old Apr 17, 2003 | 01:12 PM
HIGHRPM's Avatar
HIGHRPM
Mine "clanked" when first installed....it turned out that the front bar had shifted over an inch from center and was hitting the frame. I installed a couple of 1/4" wide collars to keep it centered....no more noises. :cheers:
[Modified by HIGHRPM, 12:13 PM 4/17/2003]
Old Apr 17, 2003 | 05:58 PM
C5stein's Avatar
0C5stein
Former Vendor
Default Re: hotchkis (HIGHRPM)
Sometimes they will shift to the side if the end links are putting preload on the bar.
To hotchkis
