Shift Light Question
Old Apr 17, 2003 | 12:47 AM
vlevick's Avatar
vlevick
Default Shift Light Question
Can you install an aftermarket shift light (Auto Meter, VDO, etc...) on a 2000 C5/A4 without using an aftermarket tach? How do you hook it up?
Old Apr 17, 2003 | 10:36 AM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Default Re: Shift Light Question (vlevick)
You hook up a shiftlight to the C5 via the PCM which is located on the passenger side under the battery.
Do a search on this subject and you will see threads that tell you exactly where to hook into.
Good luck with your mod!
