Friends vette not starting....
Old Apr 17, 2003 | 01:15 PM
Jackal's Avatar
Jackal
Default Friends vette not starting....
Thought it was the battery, but he had it replaced, and Sears is telling him that his starter is drawing to much amperage. Any thoughts?
Old Apr 17, 2003 | 03:01 PM
Jackal's Avatar
Jackal
Default Re: Friends vette not starting.... (Jackal)
Anyone?
Old Apr 17, 2003 | 03:19 PM
kromberg's Avatar
kromberg
When you turn the key what happens:
1) nothing, totally silent
2) clicking noise
3) motor turns over but does not start
4) motor turns over, pops, but does not start
5) motor turns over, starts, then dies
Needs a little bit more info.
Keith
Old Apr 17, 2003 | 04:05 PM
Jeff Jeff's Avatar
Jeff Jeff
Default Re: Friends vette not starting.... (kromberg)
Check the codes. I had a starting problem which turned out to be the key cylinder not reading the "pellet" on the key properly. If his security light flashes on the dash, this could be the culprit. Codes should identify the problem better.
Old Apr 17, 2003 | 07:31 PM
zoomnz's Avatar
zoomnz
Default Re: Friends vette not starting.... (Jeff Jeff)
Jeff Jeff,
What did you do to correct the problem you have. I also have the same problem you described. But mine is sporadic, doesnt happen all the time. I have tried to clean the cylinder with electrical cleaner and have cleaned the pellet on the key, but problem still pops up occasionally. Please help me out by telling me what was done to correct and who did it.....I see we both live in the DFW area. Thanks alot.
ZOOMNZ
Old Apr 21, 2003 | 08:19 PM
Jackal's Avatar
Jackal
Default Re: Friends vette not starting.... (zoomnz)
its a click click. it does start sometimes, but most of the time not.
Old Apr 21, 2003 | 09:14 PM
pip's Avatar
pip
Sounds like a bad earth
To Friends vette not starting....
