Turn Signal Problem
Old Apr 17, 2003 | 08:46 PM
Monkeyboy's Avatar
Monkeyboy
Default Turn Signal Problem
I've got a problem. My turn signals are intermittently failing to come on. Sometimes they do, sometimes they don't. Anyone ever have this problem?
Greg Burch -- -- 01 Torch Red Coupe MN6: http://gregburch.net/cars/vette20020907.html
Performance Mods: Blackwing filter/intake, drilled "foglight ducts", Granitelli MAF, Vortex airbridge, smooth coupler; Z06 wheels & tires, Borla Stingers, X-pipe, Hurst shifter
Information Mods: Pentium 4, 10" screen; GPS nav (EarthMate/Delorme); EFILive car data system; 10+ GB of MP3s
Appearance Mods: BPE fixed headlights, blacked-out lower rear fascia; TR exhaust plate; CAU lettering inside & out; body-color radiator cover, coolant tank & windshield washer tank; painted front calipers; polished stainless under-hood accents
Upcoming Mods: ???
Previous Vette: 95 Torch Red MN6 Coupe (aren't all vettes red?)
Old Apr 18, 2003 | 09:52 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Turn Signal Problem (Monkeyboy)
Nope. Not here. Could be your turn signal switch, flasher, or more likely just a poor connection/bad ground.
Old Apr 18, 2003 | 10:02 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Hazard warning switch :yesnod: Next time they stop working,play with the hazard button,if they start working again,you know it is a faulty warning switch...Common porblem :yesnod:
Old Apr 18, 2003 | 10:08 PM
pewt2k's Avatar
pewt2k
Had same problem with my signals, when they wouldn't work I could hit the flasher to get them going again.I took it to the dealer, and got it fixed under warranty. They replaced switch 10406626.
Old Apr 19, 2003 | 06:52 PM
EWill3rd's Avatar
EWill3rd
Default Re: Turn Signal Problem (pewt2k)
very common problem, when the signals won't work, wiggle the hazard switch and they will come back on.
You have to remove the IP trim pad to replace the switch if memory serves.
Good luck.
EWill
Old Apr 19, 2003 | 07:06 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
I would put money on the hazard relay switch in the dash. About $75 parts and labor. Had mine changed about 2k ago. :cheers:
To Turn Signal Problem
