Help finding posts for tire sensor activation ??
Old Apr 18, 2003 | 07:27 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Default Help finding posts for tire sensor activation ??
Honestly, I've been trying, but I've been unable to find the threads wherein a Tech 2 was used to activate the computer on a Z06 to permit tire pressure sensor readouts. Can someone help ? Thanks.
Old Apr 18, 2003 | 08:11 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Help finding posts for tire sensor activation ?? (wamara)
I know the thread you mean, but I couldn't find it either.
I did find this page though, it should be what you need to know:
http://www.techvelocity.com/gtp/RPO.htm
Forum members Z06 Quin or SAXN8R seem to be familiar with this procedure, look them up if the above page doesn't answer your questions.
:cheers:
Old Apr 18, 2003 | 08:19 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Simple,on the Tech2 go into the BODY section.Then choose RFA (remote function activation) from the BODY sub-section.There you will find the Tire sensor activation screen :thumbs:
Old Apr 18, 2003 | 11:14 PM
Guest
Guest
Posts: n/a
It's in the Tools menue under 'tech tips'
Old Apr 19, 2003 | 09:51 AM
wamara's Avatar
wamara
Default Re: Help finding posts for tire sensor activation ?? (MMI)
Thanks guys. I believe Aaron Lephart was the fellow who did this; can't remember his forum name to search for this thread, though. I do believe this should do the trick, in any event.
MMI, I had checked the C5 Tech Tips section, but I'm not referring to "resetting the tire pressure sensors", which was the only close tech tip that I saw. Am I missing something? Thanks.
To Help finding posts for tire sensor activation ??
