What programming is REQUIRED for A4 gear change?
Old Apr 20, 2003 | 02:52 AM
vrumvrum's Avatar
vrumvrum
Default What programming is REQUIRED for A4 gear change?
I just can't stand to see that 3.42 rearend sitting on the garage floor so I'm getting ready for the big 2.73 to 3.42 gear change swap. I like to see what performance improvements each mod gives me, so I want to do the MINIMUM amount of programming until after I see what the 3.42's are going to do for me. Then I'll go for shift points, spark advance curve, etc. I was told that the speedometer is going to be wrong and that's the only program change that would be required. :party:
Old Apr 20, 2003 | 03:33 AM
jmX's Avatar
jmX
Default Re: What programming is REQUIRED for A4 gear change? (vrumvrum)
I thought the C5 reads speed off the rear axle so it doesnt' matter what gears you put in, the speedometer will be correct.
Old Apr 20, 2003 | 07:22 AM
Jackj42's Avatar
Jackj42
Default Re: What programming is REQUIRED for A4 gear change? (jmX)
I have been told several times you will need to re-program. There are other threads on this forum on this issue.
Jack
Old Apr 20, 2003 | 09:26 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
The speedometer will not be incorrect w/o programming unless tire diameter is changed. People repeat that there will be speedo problems ad nauseum without know what they are talking about.
However, you can all but bank on shift point and P1870 issues till you do you're programming. Part throttle shifts are not much of an issue (a little high), WOT shifts are likely to hang on the limiter. The P1870 stuff is a direct result of miscal.
If you're really in the "do something then measure" camp, you're a prime candidate for using LS1-Edit, Predator, etc yourself. (I'm an advocate of LS1-Edit. :yesnod: ) I presume you're wanting to hold off completely on programming until you can do everything at once? You will not want to wait very long for your gear programming to be done. It's possible to make only gear change related adjustments without doing any additional engine tuning.
Old Apr 20, 2003 | 09:43 AM
Corvette Poor's Avatar
Corvette Poor
I am also changing from a 3.15 to a 3.42 Will a Hypertech PPIII be suffecient to do the programming I will need ?
Old Apr 20, 2003 | 10:04 AM
ToplessTexan
Default Re: What programming is REQUIRED for A4 gear change? (Corvette Poor)
I know of only one person who claimed to have an HPP3 that offered 3.42 as an option for an A4 car. I was using an HPP3 prior to my gear swap, which I delayed until LS1-Edit was available. Sold my HPP3 after that. No an HPP3 won't do what you're after. The advertising is/was a bit misleading.
Don't try the tire scaling trick you hear thrown around from time to time. It works for F-body but will miscalibrate your speedometer.
The 3.15->3.42 swap is the only one that's a small enough change in gear to offer hope that you can squeak by for a longer time miscalibrated. Mike Mercury is the canonical example.
[Modified by ToplessTexan, 9:06 AM 4/20/2003]
Old Apr 20, 2003 | 05:40 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: What programming is REQUIRED for A4 gear change? (ToplessTexan)
TTexan is correct. Depending on your C5 year (2001 and newer), you need do NOTHING in the way oof reprogrammign when going from the 3.15 to the 3.42 and retain your stock torque convertor.
Regardless of year, going from 2.73 to any other gear ratio will require a reprog. It has nothing to do with the speedometer and everything to do with the PCM's factory program not liking the higher RPM in each gear. Taking the 2.73 to any other ratio (even to the 3.15) is too wide a variance and the PCM will probably cause ackward shifting and will most likely throw error codes.
I think it has been determined that the Hypertech will not do gear rescalling properely on a C5 (although it will work fine on F bodies).
The Predator and LS1-Edit are viable DIY reprog options.
for those that haven't yet, visit my web page on this subject:
mikemercury.home.att.net/342.htm
Old Apr 20, 2003 | 08:34 PM
1 slow 97's Avatar
1 slow 97
do it, you will be so happy. I do feel my speedo is of slightly and the shift points are definently different then they where with the old gears. I am going to do LS-1 edit after I get my headers and converter in. But for now, the car seems to be okay. Good luck, as soon as you do that you will want more power and soon you will have the mod bug!
Old Apr 20, 2003 | 08:45 PM
Mike Mercury
Default Re: What programming is REQUIRED for A4 gear change? (1 slow 97)
I do feel my speedo is of slightly...
the VSS is located on the output shaft of the rear carrier. It's rotational speed will not change unless the tire diameter is altered.
There is no guesswork here on that specific.
If you think you know better, then please provide your source.
Old Apr 20, 2003 | 09:43 PM
clancy's Avatar
clancy
:iagree: :iagree:
You will have to change your MPH shift points or you WILL hit the rev limiter, also make the change from 2.73 to 3.42 by some program,I used the LS1 Edit, thats all you HAVE to do. Then go play & have a lot of fun :cheers:
Old Apr 21, 2003 | 02:16 AM
vrumvrum's Avatar
vrumvrum
Default Re: What programming is REQUIRED for A4 gear change? (clancy)
Cool, I already have 2 other guys and myself to pitch in on LS1 edit, I get an income tax refund, got a good mechanic lined up. I'm going to have to think real hard about swapping the converter. I'll see if I can find someone around I can do a test drive.
I decided to get the 3.42 after visiting Mike Mercury's site a month ago. It's got a LOT of good info. :smash: :smash: A valueable asset to the Forum.
Hopefully LS1 edit is straight forward.
To What programming is REQUIRED for A4 gear change?
