newbie tire pressure sensor question
Old Apr 20, 2003 | 10:36 PM
Gezzer's Avatar
Gezzer
Cruising
Default newbie tire pressure sensor question
If I take off the wheels are there any connections from the wheel to the car to consider? If so, what's the procedure? THANKS! :confused:
Old Apr 20, 2003 | 11:00 PM
paid4c4's Avatar
paid4c4
Default Re: newbie tire pressure sensor question (Gezzer)
Theres nothing that has to be disconnected. The tire pressure sensors are small radio transmitters, thus no wires!
Bill :) :)
Old Apr 21, 2003 | 01:15 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Geezer:
The post above is correct, these sensors are 'radio', thus no wires.
The question for you is what was your concern - taking the wheels off, or attempting to remove the tires from the wheels? If you are taking the tires off the wheels, it is a normal procedure (as associated with any other tire removal).
If you are changing wheels, the sensors are a 'part' of the valve stem. Removal of the stem 'cover' will release the internal unit from the wheel.
Be sure to NOT over- torquing the stem cover, or possible damage to the 'washer' will result, or worse yet, it is possible to break the stem away from the sensor.
To newbie tire pressure sensor question
