[Air Conditioning] Diagnosis please???
Old Apr 21, 2003 | 04:24 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default [Air Conditioning] Diagnosis please???
My car has been on jackstands for over 3 months now waiting on rims. I have been cranking it up every 2 weeks or so. Last weekend I just happened to turn the AC on but the AC light just blinked a few times then went off. Everytime I push the AC button it would do the same. I also could not hear the compressor kick on at all. Anyone know why all the sudden my AC would quit working. I did hook a charger up b/c my battery went south the first month. I am thinking it could be a fuse. Which one would I check?
Thanks, Michael.
Old Apr 21, 2003 | 05:58 PM
JCR's Avatar
JCR
Default Re: [Air Conditioning] Diagnosis please??? (C5-VERT)
Replace switch. You could try bypass first and see if a/c kicks on
Old Apr 21, 2003 | 06:03 PM
SAXN8R's Avatar
SAXN8R
I think there is a problem with your system. There is probably some sort of low preassure switch that won't allow the compressor to come on if it is low on refrigerant. I am pretty sure the blinking light means trouble. Did you try to pull up codes from the DIC? If there is a problem, there may be a code under HVAC.
Old Apr 21, 2003 | 06:38 PM
texasredc8's Avatar
texasredc8
Compressor won't kick on if the temp is below 40 degrees
Old Apr 21, 2003 | 08:30 PM
C5-VERT's Avatar
C5-VERT
Default Re: [Air Conditioning] Diagnosis please??? (TexasRedZ06)
Well unfortunately it is 70-80 degrees.
SAXN8R I simply forgot to check the codes. Will do so when I get back to Savannah where my car is at. I am NOT getting a "Check Engine" light.
Old Apr 21, 2003 | 08:41 PM
Wt99C5's Avatar
Wt99C5
C5-VERT, I have a spare set of rims sitting here.
Let me know if you'd like to borrow them.
Old Apr 21, 2003 | 08:42 PM
SAXN8R's Avatar
SAXN8R
You will not get a check engine light unless you have an emmissions related problem.
To [Air Conditioning] Diagnosis please???
