Belt squeak, cheap easy fix - maybe??
Old Apr 21, 2003 | 08:25 PM
Miaugi's Avatar
Miaugi
Default Belt squeak, cheap easy fix - maybe??
I recently read a couple of posts about squeaky belts, Saturday I'm out and what do I hear at a red light, my belt squeaking!!! It was most noticable at idle and would disappear at 1,200 -1,300 rpm. When I got home I tried an old remedy that I remember seeing done as a kid, a bar of soap rubbed against the belt while engine running (in this case Irish Spring).
This is not something to be done if you are not extremely careful, running belts will mess up fingers very badly if you are careless! I was careful and there is room to get to the belt in a couple of different spots, so far the squeak is gone, and the engine smells fresh and clean. :D
[Modified by Miaugi, 9:00 PM 4/21/2003]
Old Apr 21, 2003 | 09:42 PM
KyleBst264's Avatar
KyleBst264
Default Re: Belt squeak, cheap easy fix - maybe?? (Miaugi)
Use Ivory soap instead, it works better for this purpose.
Old Apr 21, 2003 | 09:44 PM
BOB CROFT's Avatar
BOB CROFT
Default Re: Belt squeak, cheap easy fix - maybe?? (KyleBst264)
Is this an old wives tale ?
Old Apr 22, 2003 | 07:58 AM
stevenll's Avatar
stevenll
Don't know about using soap, but belt dressing can cure a squeek if the belt isn't too loose.
To Belt squeak, cheap easy fix - maybe??
