What does GM consider excessive oil consumption?
Old Apr 21, 2003 | 11:18 PM
CRUZMISL's Avatar
CRUZMISL
Default What does GM consider excessive oil consumption?
Just curious because I burned a quart or so on my trip to Florida which was about 1200 miles. Cruising about 85-90 on the highway in 6th. What really got me thinking was the huge amount of black crap on the rear fascia when I got there. IS that related?
Any thoughts?
Joe
Old Apr 21, 2003 | 11:39 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: What does GM consider excessive oil consumption? (CRUZMISL)
I was told 1/2 quart per 500 miles. Dealer checked mine every 500 miles. Verified 3 times and then reringed it. Mine had oil blown all over the a** end too. I told the dealer we didn't need a consumption test - just rub your finger along the a**end of my car!!! He didn't think I was very funny...I wasn't trying to be - I was serious!! Take yours in for a test and get your new rings. Good Luck!! :cheers:
Old Apr 22, 2003 | 02:13 PM
MVP's Avatar
MVP
I was told 1 quart every 1000 miles.
Theoretically (sp?) you don't need to change you oil then. 6.5 quarts 6000 miles, just change the filter, there is always fresh oil in there. :jester :nopity
Old Apr 22, 2003 | 03:20 PM
1SGRET's Avatar
1SGRET
St. Jude Donor '12-'13
Default Re: What does GM consider excessive oil consumption? (MVP)
GM says 1 quart per 2000 miles is acceptable. Anymore is excessive usage. Mine used 1 quart per 1200 miles and I had mine re-ringed without an oil consumption test. No more usage! :auto:
Old Apr 22, 2003 | 03:38 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: What does GM consider excessive oil consumption? (1SGRET)
I got lucky. I burn 1 quart every 7,000 miles.
To What does GM consider excessive oil consumption?
