Headlight problem
Old Apr 22, 2003 | 12:42 AM
Vette#4's Avatar
Vette#4
Default Headlight problem
Ok, I came home last night, drove into the garage and shut everything
off...then noticed that my driver's side headlight popped back up about
1 inch or so...turned the lights back on and off several times and it keeps
doing the same thing...has anyone else had this problem, and if so, how
do you get rid of this headlight demon :banghead:
Old Apr 22, 2003 | 12:50 PM
carpe dm's Avatar
carpe dm
Default Re: Headlight problem (Vette#4)
Sounds to me as though you have crunched one of the little plastic/nylon stops that control headlight placement. It is probable the lowest stop, under the light unit. Gert a flashlight and take a peek at those stinkers; pull one off the top rear to use as a replacement. Good luck. :)
