Bassani X Pipe, Bolt or Wield???
Old Apr 22, 2003 | 09:56 AM
mbanks21's Avatar
mbanks21
Default Bassani X Pipe, Bolt or Wield???
Hey guys Im looking at either a Bassani X Pipe or the full length replacement X, and my question is which would be better for power and sound and if anyone knows if they are direct bolt ons or would I have to wield? Thanks!
Old Apr 22, 2003 | 08:04 PM
Greg_E's Avatar
Greg_E
Default Re: Bassani X Pipe, Bolt or Wield??? (mbanks21)
To install the Bassani X pipe you will need to cut the existing H pipe following the diagram that should be supplied with the X pipe. (I say should because it was missing from the box when I received mine. The pipe can be clamped in the front with the supplied Torca clamps or welded if you prefer. The other end has flanges that bolt up to the Mufflers. The stock bolts are about 1/2" short because the flange on the Bassani is thicker. These are not supplied so make sure you get some before you start the install. :seeya
