Another way to do the PVC mod......
Old Apr 22, 2003 | 04:42 PM
BrewsVet's Avatar
BrewsVet
Default Another way to do the PVC mod......
I thought it was awkward to run the filter lines over to the wheel well so I attached mine to the air filter/fan housing by drilling 2 small holes in the edge and tie wrapping the filter with 90 degree barbs on it. Notice I also moved the PCV valve beyond the filter and just before the intake. I have yet to notice any oil in the filter but I haven't done any WOT's since the installation either.
[Modified by BrewsVet, 3:16 PM 4/23/2003]
Old Apr 22, 2003 | 04:46 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: Another way to do the PVC mod...... (BrewsVet)
Well done, I like it. :cheers:
Old Apr 22, 2003 | 04:56 PM
see5's Avatar
see5
You win, I am changing mine!
Thanks.
[Modified by see5, 3:56 PM 4/22/2003]
Old Apr 22, 2003 | 05:42 PM
blktie8's Avatar
blktie8
I can't see the pictures
Old Apr 22, 2003 | 07:02 PM
J Z06's Avatar
J Z06
Red X here.
Old Apr 22, 2003 | 07:30 PM
johnnyC5's Avatar
johnnyC5
Nice RED Xs....
From your description, I too placed the filter by the fan shroud, and drilled 2 small holes inthe palstic guard for my tie wraps. It is very solid and looks "clean"
I have my filter BEFORE my PVC valve as well, with the PVC valve sitting right before the Intake area also.... still dont understand why people place the Fitler AFTER the PVC valve :confused:
not right IMO.
Old Apr 22, 2003 | 07:31 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
I can't see the pictures either. :confused:
1SGRET's Avatar
1SGRET
St. Jude Donor '12-'13
Red "X". Sent you an email.
Old Apr 23, 2003 | 09:43 AM
Waterfreak's Avatar
Waterfreak
Default Re: Another way to do the PVC mod...... (Cobra4B)
I've been working on a little pcv mod of my own. You can see it in my webshots page at http://community.webshots.com/user/waterfreak in the folder labled "Coil Relocates, PCV MOD, CCW Wheels". The pictures are labled PCV Mod 1, PCV Mod 2 and PCV Mod 3. The system utilizes a GReddy Oil Bypass catch can right after the PCV valve. It is quite large and can hold a lot of oil. It also has a tube that runs vertical along the side of the can to show you how much oil has accumulated in the can. Since intalling it I have not had a drop of oil in my throttle body or intake manifold behind the throttle body. The system is still in "mock up" stage in the pictures, but you can get the drift. I'm going to make a nice polished bracket and add braided stainless steel lines.
Old Apr 23, 2003 | 09:54 AM
C5 Curmudgeon's Avatar
C5 Curmudgeon
Default Re: Another way to do the PVC mod...... (vette#one)
:iagree:
Old Apr 23, 2003 | 10:05 AM
User 81424's Avatar
User 81424
Default Re: Another way to do the PVC mod...... (johnnyC5)
Nice RED Xs....
not right IMO.
Because it's quick and easy, and easy to reverse.
Old Apr 23, 2003 | 10:17 AM
Waterfreak's Avatar
Waterfreak
Default Re: Another way to do the PVC mod...... (eddiep)
I just uploaded them to the webpage. Sometimes it takes them up to a half hour before they are available for public viewing. You should be able to see them now.
Old Apr 23, 2003 | 12:49 PM
ReddyZ06's Avatar
ReddyZ06
Default Re: Another way to do the PVC mod...... (Waterfreak)
Waterfreak,
Nice photos. My GReddy catch can is mounted in almost the same place with a plate spaced 3/8" from the head but bolted to the head. No extended road trips on it yet. I wondered what you thought of the heat where you have yours mounted, mine hets very warm but seems acceptable.
Mike
Old Apr 23, 2003 | 02:33 PM
HOTSOSS's Avatar
HOTSOSS
Pardon my ignorance, but what is the purpose of the PVC modification?
Old Apr 23, 2003 | 04:55 PM
Waterfreak's Avatar
Waterfreak
Default Re: Another way to do the PVC mod...... (ReddyZ06)
The temporary bracket is bolted to the head as will be the permanent one. It gets hot, but it really doesn't matter if it's hot as long as it catches and holds the oil.
The purpose is to isolate the oil that blows by the pcv valve so that it doesn't enter the intake manifold and get burned.
Old Apr 24, 2003 | 08:09 PM
99 C5 Coupe's Avatar
99 C5 Coupe
All this talk about the PCV mods made me look at my TB and sure enough. There was a ton of oil in the intake and TB. I also pulled the spark plugs and even though the center electrodes were light tan colored (20K miles) The threads and inside area of the plugs were really oily. So I'm putting a filter on the valve cover vent and the PCV line. We'll see how it works.
Old Apr 24, 2003 | 09:05 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Re: Another way to do the PVC mod...... (99 C5 Coupe)
Looks nice. For all you people that have done the PCV mod, especially those that catch quite a bit of oil, how often do you have to top off the oil?
I'm averaging 1/2 qt per 800 miles. I haven't done the PCV mod yet, and am wondering how much oil has caked on the inside of my intake.
To Another way to do the PVC mod......
Old Apr 24, 2003 | 11:07 PM
24power's Avatar
24power
mine is after the valve and works great.......caught about a teaspoon over a 1000 miles..... :steering:
Old Apr 25, 2003 | 12:57 AM
batsallover's Avatar
batsallover
That is the cleanest install of the PCV MOD I have seen. :cheers:
Old Apr 26, 2003 | 02:30 PM
99 C5 Coupe
Default Re: Another way to do the PVC mod...... (batsallover)
Does anyone know why there is a ground wire on the PCV check valve?
