I think I may have a the same problem with mine. I believe I have some communication issues between the BCM and the PCM resulting from the Superchips programming that came with my Procharger. The car is going to a dealer about an hour away from here next week. The Superchips rep works there also. They plan on "pinging" each of the car modules to see which one is not responding correctly.
I THINK some issues don't clear unless the car starts a number of times (50) without a reoccurance of the problem. Try disconnecting the battery for a while (30 minutes) and see if the light clears? I'm guessing here. :cheers:
