Basic spark plug wire question
Old Apr 23, 2003 | 02:16 PM
Mavrick's Avatar
Mavrick
Default Basic spark plug wire question
Installed new plugs last night and Magnecor wires. Any problem using the stock heat shields, they fit the magnecor boot just like the stock wires.
By the way, you were all right, that drivers side plug is a :cuss :cuss :cuss
Old Apr 23, 2003 | 02:20 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Default Re: Basic spark plug wire question (Mavrick)
I think that many actually recommend reusing the boots - I did!
Old Apr 23, 2003 | 02:32 PM
YELLOHHH's Avatar
YELLOHHH
You definatley want to reuse the stock heat shields. You will burn the boots if you don't.
Greg
:steering:
Old Apr 23, 2003 | 02:33 PM
Wt99C5's Avatar
Wt99C5
Try removing the coil packs and the AIR tube next time. It saves time and you won't loose so much blood. Just an option.
Old Apr 23, 2003 | 03:02 PM
blktie8's Avatar
blktie8
Talk to steve at Magnecor
http://www.magnecor.com/
[Modified by blktie8, 3:38 PM 4/23/2003]
Old Apr 23, 2003 | 04:00 PM
Mavrick's Avatar
Mavrick
Default Re: Basic spark plug wire question (Wt99C5)
Knew I should have posted this question BEFORE I swapped them out, thanks for the info, will try it next time.
To Basic spark plug wire question
