Losing oil
Old Apr 23, 2003 | 11:00 PM
samricky's Avatar
samricky
Default Losing oil
I have been having to add a couple of quarts of oil between changes. The floor is dry, so it's not coming out the bottom. I also haven't noticed any smoke. Is this a ring problem, and is this common? I assume that my warranty would cover this problem.
Old Apr 24, 2003 | 01:38 PM
jeanlucpicard's Avatar
jeanlucpicard
Default Re: Losing oil (samricky)
Since your sig says you own a 1999 model I doubt your car is a candidate for the "oil consumer club". I have a 2001 and that was the only model year that GM went stupid and installed their "low tension" rings to help with gas mileage. Odds are you are simply buring the oil. If you do not see any leakage or drips along the undercarriage and engine area, you have to be burning it. And oil burning does not necessarily mean blue smoke out the tailpipes.
One caution, oil going out the tailpipe will eventually kill your catalytic converters by contaminating the sulphur catalyst. You may want to get this oil issue checked before you fail an emissions test.
SAVE THE WAVE :seeya :cheers: :cool:
Old Apr 24, 2003 | 02:03 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Sam , i'm assuming that you change your oil every 3000 Miles..If thats the case then 1 Qt of oil every 1500 Miles is not out of the ordinary.
However , it's your choice..You can bring your car to the dealer and tell them that you want to under go the GM OIL CONSUMPTION TEST.
If the car is consumeing what they deem excess oil they will cover your ring job under your warranty.
Good Luck !
Jeff
To Losing oil
