Jet Power Module
Old Apr 24, 2003 | 11:15 PM
9vette9's Avatar
9vette9
4th Gear
Default Jet Power Module
Need help installing a Jet power control module. Where does it go. :nonod:
Old Apr 25, 2003 | 12:44 AM
twincam47's Avatar
twincam47
Default Re: Jet Power Module (9vette9)
It goes right behind the right front wheel. Take the lower panel off of the inner fender well (there are bolts that also are underneath the car attahced to the same panel). from underneath you will see 2 long wiring harness plugs. I beleieve its the red one you unplug and then plug in the JET and then plug the harness into the jet. The black plastic cover of the harness has to be removed to allow the fender well cover to be replaced. Also you module should have com with an accessory bolt which lengthens the original bolt so that both the module and harness can be re attached. If you ain't got this part dont even start.
Try http://www.jet.com maybe they have the install instructions on the web. :flag
