C5 Posi is toast
Old Apr 27, 2003 | 02:55 PM
c5man99's Avatar
c5man99
Default C5 Posi is toast
Any one know of an aftermarket or ?? to beef up the clutch pack? Is there a locker for a C5? What does everyone do to keep them together?
Thanks, :steering:
Old Apr 27, 2003 | 04:04 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Re: C5 Posi is toast (c5man99)
Hey copy cat!!!!!! I break mine you break yours. :lol: If you find something better than what we have give me the info. :D
Bob
Old Apr 27, 2003 | 04:13 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: C5 Posi is toast (16Again)
Bob
damn, that's right Bob...and with Rodney, that makes 3 C5s this weekend, excluding Redgar :(
so...what exactly is the posi unit in comparison to the tranny, gears, converter, etc....is it an actual separate component or part of the gears, etc...something that could be beefed up with I get my stuff installed :)
Old Apr 27, 2003 | 04:42 PM
16Again's Avatar
16Again
Default Re: C5 Posi is toast (Mean Green 2000)
Bob
Seperate part, actually a clutch pack in the differential. Connects both wheels so they each have equal power. Cluthes slip and power only goes to one wheel. Don't know if anything special is available yet. Should know in a day or so if anyone makes anything that's better.
Bob
Old Apr 27, 2003 | 04:55 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
so it's in or part of the differential then, hmmmm....keep us updated, and have you talked to Tracy's tranny man, just another resource :)
Old Apr 27, 2003 | 05:25 PM
16Again's Avatar
16Again
Yes it's actually a part of the rear but, the clutches can be replaced as they do wear when abused (drag racing). For the record both Marc's car and mine were clutch pack failures probrably caused by wear (or John Force burnouts). Rodney had some type of failure entirely unrelated to our problem. Until his car is taken apart we won't know what caused it. By the way my rear was never apart. It was removed from a brand new car and put right into mine.
Bob
[Modified by 16Again, 5:26 PM 4/27/2003]
Old Apr 27, 2003 | 06:20 PM
chuckster's Avatar
chuckster
Are any of these rears "REBUILT" with 3:73, 3:90 or 4.10's??
I posted this a while back. I was curious to know the condition of the posi that was in the case before they rebuilt it. For all we know they could have had 50-100K miles...
Old Apr 27, 2003 | 06:47 PM
c5man99's Avatar
c5man99
Default Re: C5 Posi is toast (chuckster)
In my case, the Diff came out of an '02, very low miles......leaking side cover, warranty replacement...........it was a 3.42 that I used for my 3.73's.
Old Apr 27, 2003 | 06:50 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
sorry to hear that Marc :(
Old Apr 27, 2003 | 07:37 PM
16Again's Avatar
16Again
Marc's unit was a factory 3.42 that had 3.73 gears installed. Mine was a factory 3.42 that was removed from a new car and installed in my car. Never opened. Mine currently has about 20,000 miles of which I put on. Lots of dyno, street and race track. Thankfully the weak link is a fairly inexpensive failure. Just a coincedence, we play now we pay.
Bob
Old Apr 27, 2003 | 08:25 PM
chuckster's Avatar
chuckster
Good thing....
Caus I have 4.10's and was worried... :D
Old Apr 27, 2003 | 08:55 PM
NealB's Avatar
NealB
for several years I've bought stuff from a place called Drive Trail Specialists, or DTS
they have stuff for about any posi of any kind from any manufacturer
including stronger than stock
Old Apr 27, 2003 | 09:21 PM
c5man99's Avatar
c5man99
Default Re: C5 Posi is toast (NealB)
Thanks, I just sent them mail.
Old Apr 27, 2003 | 10:29 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Sorry to hear that things are breaking... but you know what they say about racing... if things arent breaking, you are not trying hard enough... ;)
My understanding is that the diff in our cars is a limited slip... If you built it for a Posi, that would prob help out your drag racing.. :yesnod:
vetterdstr :cheers:
Old Apr 27, 2003 | 11:01 PM
c5man99's Avatar
c5man99
Default Re: C5 Posi is toast (vetterdstr)
Thanks for the insight!
Old Apr 27, 2003 | 11:14 PM
vetterdstr's Avatar
vetterdstr
Anytime! :D :cheers:
vetterdstr :chevy
Old Apr 28, 2003 | 04:24 PM
vstella's Avatar
vstella
Sorry to hear that your having trouble Marc..But this is whiy I purchased 3.73's direct from Getrag..Nothing like a new component with a warranty!
Hope you get it sorted out real soon..I'm looking to get to the track in about 2 weeks and I could use a partner for the Moroso dial in runs... :yesnod:
To C5 Posi is toast
Old Apr 28, 2003 | 04:33 PM
Carsnob's Avatar
Carsnob
Default Re: C5 Posi is toast (vstella)
Try a company called auburn gear. I don't know if they make anything for the C5 but it would be worth looking into.
http://www.auburngear.com
Old Apr 28, 2003 | 05:05 PM
c5man99's Avatar
c5man99
Vince,
Unfortunatly, with the power we are putting to the rear, an OEM dosen't seem to be able to handle it.....we think the clutch packs need to be shimmed tighter. :steering:
Old Apr 28, 2003 | 05:08 PM
c5man99's Avatar
c5man99
Default Re: C5 Posi is toast (Carsnob)
Thanks for the heads-up, Carsnob! I e'd them.
