Who sells the best 4:10 carrier. Just had one installed and did not last a day at the track. I believe it is the rear it makes the most noise at low rpm( 2000-2500)in high gear on the highway and goes away when you let off the gas or push in the clutch. Any suggestions as what this could be or who to get carrier from would be greatly appreciated. THANKS, JOHN :sad:
From: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
Re: rear ends (ITSovr4U)
Give Rodney (crashed 94) a call (765)520-8368 , he has done many gear installs and 6 speed tranny upgrades to forum members including mine with nothing but compliments and praises ! :steering:
Mine does the same thing...whines around 1900-2200, mostly in 6th gear.
I got mine from Andy at A&A Corvettes. He's supposed to be replacing it under warranty but apparently has too much other work because he hasn't called as promised. It only took him a week to get the gears in the first place but after several months he still hasn't gotten the replacement set for the warranty!!!
I understand that he got mine from West Coast Corvettes.
Thanks for the "heads up", I was getting to ready to get my gears from A&A also.... :thumbs:
