Brake advice needed!!
Old Apr 28, 2003 | 10:39 AM
sanchez's Avatar
sanchez
Default Brake advice needed!!
I am changing my brake pads, it's that time again and was wondering about getting my rotors turned. I have the 2 piece Baer Eradispeed setup and wasn't sure if these even needed to be turned.
Thanks in advance,
Sam
Old Apr 28, 2003 | 11:00 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Brake advice needed!! (sanchez)
no
Old Apr 28, 2003 | 09:29 PM
CHJ In Virginia's Avatar
CHJ In Virginia
As long as the pads are not totally gone and the backing plate is eating into the rotor surface, and you have no pulsation, I would not resurface them. The slots/holes will allow the new pads to seat quickly to the contour of the rotor. I would burnish the glaze off the rotor friction surfaces with some 6-800 grit sand paper. Lightly sand just enough to see difference. You should be fine.
To Brake advice needed!!
