PCM Calibration program?
Old Apr 30, 2003 | 07:18 PM
JCR's Avatar
JCR
Default PCM Calibration program?
How does one know what program is in the car. Can this be determined by any diagnostic tool or is this privy to GM only. Can any shop reprogram to latest GM program or is this also privleged info. limited to chevy dealerships?
Old Apr 30, 2003 | 08:03 PM
02coupe's Avatar
02coupe
Default Re: PCM Calibration program? (JCR)
http://www.diablosports.com/
This will help you modify your car
Old Apr 30, 2003 | 09:23 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Calibrations are read by inserting the VIN# into the GM website...Program updates are determined by retreiving the calibration from the PCM with a Tech2,downloading that calibration from the TECH2 to a PC connected to the GM data base...If there is an update,that calibration is downloaded to the TECH2 from the PC,then downloaded to the car with the TECH2...Got all that??? :crazy:
If you e-mail me your VIN#,I can tell you if there is an update calibration :yesnod: which there is for just about every GM vehicle on the road...
I beleive a bill was passed recently to release these calibration updates,but if one does not have the equipment they are SOL :yesnod:
Old May 1, 2003 | 04:26 AM
z0sense's Avatar
z0sense
If a shop has ls1 edit near you..they can flash a stock program to your computer. Or you can go to any local dealer and they can flash your pcm.
Tp actually view the data you will need a Tech 2 (as mentioned), ls1 edit, or the new Genisys (by OTC tools which is half the price of the Tech 2 and can do the same, if not more then it. Plus it is in full color!)
[Modified by z0sense, 3:27 AM 5/1/2003]
Old May 13, 2003 | 07:14 PM
Longhorn FRC's Avatar
Longhorn FRC
Default Re: PCM Calibration program? (z0sense)
will GM reflash your PCM for free if the car is out of warranty? just wondering if I would see any gains by having it updated.
Old May 13, 2003 | 07:43 PM
JCR's Avatar
JCR
Default Re: PCM Calibration program? (Longhorn FRC)
I heard that it runs 80-100.00 bucks.. It seems that GM has the exclusive on this. I would sure like to know beforehand that a new update is available before shelling out 100 bucks to find out?What happens if there is no update.. Thanks for 100.00..have a good day!!
Old May 13, 2003 | 08:07 PM
Longhorn FRC
ehhhh, geez. I think I'll be sticking with the current calibration.
Old May 13, 2003 | 08:21 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
LS1-Edit writes data segments only, not code segments. If you use LS1-Edit to write data segments from a different cal id to your PCM you are begging to be hosed. :nono: This trick will usually result in your PCM becoming a mighty fine paperweight.
Old May 13, 2003 | 10:43 PM
bowtiebandit's Avatar
bowtiebandit
Default Re: PCM Calibration program? (C-5 TECH)
You can also go here to look here for updates..
http://calid.gm.com/vci/
Old May 14, 2003 | 07:07 AM
Rx7Rob's Avatar
Rx7Rob
Default Re: PCM Calibration program? (bowtiebandit)
My car goes in to check out a few things next week. This is 5days before the warranty is over. Should I have them check for and install any updates? Or am I better off with not fix'n what ain't broke?
edit: Ok, I just checked the web page and found the only update is "new calibration to reduce spark knock and false setting of dtc p0175".
Well, about a year ago my car started feeling like it doesn't want to pull to redline. I ran Autotap and found a lot of knock retard.
Anyone know if the update changes knock sensitivity to reduce the amount of retard, or did they increase the sensitivity and increase knock retard.
I can't remember if the knock retard I'm seeing coensides with the cars trip to the dealership last year. (maybe they flashed it and didn't tell me).
[Modified by Rx7Rob, 7:26 AM 5/14/2003]
Old May 14, 2003 | 10:02 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: PCM Calibration program? (Rx7Rob)
http://www.easediagnostics.com/sps/data/sps.htm
To PCM Calibration program?
