FOB prob
Old May 2, 2003 | 03:32 AM
Blackjetvette97's Avatar
Blackjetvette97
Default FOB prob
Hi all,
I cannot figure out why my FOB won't hold calibration after I re-synch it. I have a new battery in it and the car and have done the resynch thorough the DIC. My TPS' work fine, so it isn't the receiver unit, is it? ANY ideas?
Steve
Old May 2, 2003 | 10:21 PM
rhoeven's Avatar
rhoeven
Default Re: FOB prob (Blackjetvette97)
Had same happen to me. The spare fob was working ok.
It was the fob which was bad.
Does the 2nd fob work correctly?
Ordered replacement fob from Ken Fichtner here on the forum.
Hope this helps.
Roger
[Modified by rhoeven, 7:23 PM 5/2/2003]
[Modified by rhoeven, 7:25 PM 5/2/2003]
Old May 2, 2003 | 10:48 PM
cortex's Avatar
cortex
Default Re: FOB prob (rhoeven)
I have the same problem, including both fobs, so it's probably the receiver in my case?
Hopefully someone will chime in. I wonder if there is any way to "test" the receiver, other than with a fob :confused:
Old May 2, 2003 | 11:37 PM
bowtiebandit's Avatar
bowtiebandit
Default Re: FOB prob (cortex)
Without having a Tech 2 to watch the receiver status while pressing the fob your pretty much takin a shot in the dark. The receiver has changed part numbers 3 times so it is a safe bet thats the problem, but you may want to see if it has set a code to make sure.
RKE and/or Low Tire Pressure Monitoring System Inop (Replace RKE Module) #99-08-52-002 - (04/20/1999)
Remote Keyless Entry System (RKE) and/or Low Tire Pressure Monitoring System Inoperative (Replace RKE Module)
1997-98 Chevrolet Corvette
Condition
Some customers may comment on the following conditions:
The remote keyless entry system (RKE) is intermittently inoperative.
The Driver's Information Center is inoperative or it displays the following messages intermittently and usually at start-up of the vehicle:
Low tire pressure.
Tire pressure trouble codes may occur.
Cause
When the ambient temperature of the interior is less than 10° C (50° F), some oscillating transistors may stop working. However, when the interior warms, they begin to work with the next key cycle. The module in question is P/N 10401040.
Correction
Replace the RKE Module with P/N 10422621.
Parts Information
Part Number
Description
10422621
Module, Keyless Entry & Low Tire Pressure Module
Old May 3, 2003 | 04:32 AM
Blackjetvette97
Default Re: FOB prob (bowtiebandit)
Hi all,
Thanks for the replies. I know there is a tool that is called a FOB tester, but my dealer said someone had stolen theirs when I went to ask for a test. I had to tell the service writer that they had one and give him the part #, but I have now forgotten it. Maybe a C5 tech can remember it and post the part # here. My TPS' work fine and I have no codes or DIC messages upon startup. Hmmmm, must be the fob from one too many drops.
Steve
Old May 3, 2003 | 10:08 AM
bowtiebandit
Steve
J 43241
Keyless Entry Tester
[Modified by bowtiebandit, 10:09 AM 5/3/2003]
Old May 5, 2003 | 04:36 PM
Shawn84&92's Avatar
Shawn84&92
My fobs will work right after I program them, then they will stop working.
Where is the module located?
Thanks,
Shawn
Old May 5, 2003 | 07:58 PM
bowtiebandit
Default Re: FOB prob (Shawn84&92)
The module is located under the black interior quarter trim on the left hand side. You have to separate the double sided tape from the body, pull the trim down and it sits about one third the length of the quarter.
Old May 6, 2003 | 09:03 AM
Shawn84&92's Avatar
Shawn84&92
Thanks, Bowtie. Is that the rear interior trim in the cargo area?
Thanks,
Shawn
Old May 6, 2003 | 08:03 PM
bowtiebandit
Yes it is..sent you an e-mail explaining it. :)
To FOB prob
