Oxygen sensor issues after header install????
Old May 2, 2003 | 10:41 AM
Charley Hoyt's Avatar
Charley Hoyt
Default Oxygen sensor issues after header install????
About a week or two ago I installed a set of TTS Long tube headers. The results have been fantastic....However, I am now getting codes that indicate that both of my front Oxygen sensors are going (or have gone) bad...and one of my rear sensors now appears to be going bad. Any suggestions on what could be causing this??? Any help would be greatlly appriciated.
Thanks,
Old May 2, 2003 | 11:01 AM
jawski's Avatar
jawski
Default Re: Oxygen sensor issues after header install???? (Charley Hoyt)
:lurk:
Finishing my header install today.
Old May 2, 2003 | 11:06 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Are you running cats? With our headers we put O2 sims in the rear and attach the physical rear O2 sensors to the front O2 wiring harness. This is due to the insufficient switching codes we get since our headers are so long. The rear O2's actually are rated at a higher wattage and heat up faster. This clears up the problem for our customers...
Old May 2, 2003 | 11:42 AM
Charley Hoyt
Default Re: Oxygen sensor issues after header install???? (Godspeed)
Yes, I am running cats.
I am wondering if it could be related to one of several things. First, The TTS headers have a bolt in collector that requires an RTV Sealant. The sealant I used is Oxygen sensor safe….but I am wondering if it could have poisoned the sensors because I drove the car prior to the RTV setting. The other possibility is …could the sensors have been damaged when the collector was TIG welded to the cats? I would think that they are far enough away so that the heat would not have hurt them??? The last possibility that I can think of is that when the weld shop tilted down the mid section of the exhaust, to weld the collector to the cats, they could have stressed the wires on the sensors. Or could have allowed the wires to get too close to the heat of the headers???
[Modified by Charley Hoyt, 8:43 AM 5/2/2003]
Old May 2, 2003 | 12:13 PM
Avanti's Avatar
Avanti
I have always been told to disconnect the battery before doing any electrical welding on a "digital" car. If there is any validity in this, it might be at least part of your problem.
All the best. :yesnod:
[Modified by Avanti, 11:13 AM 5/2/2003]
Old May 2, 2003 | 12:23 PM
thefly's Avatar
thefly
depending on the code, sounds like an installation issue. O2 sensors are extremely delicate, if you drop one service manual says to replace it. i lost one on my install of TTS headers from installation. my dad had to have 2 replaced subsequently following installation. and i have since had the headers installed a second time on new vette and didn't getting any codes. if you replace they will be fine, but more than likely it was from installation.
Old May 4, 2003 | 01:02 AM
Charley Hoyt
FYI I installed a new set of Front O2 sensors today and everything is working fine now :) . I think that the welding killed the sensors? That was an expensive (~$100) lesson.
Old May 4, 2003 | 01:10 AM
Maverick's Avatar
Maverick
Charley, I had exact same problem. If you're not careful with the O2's during the removal, most likely it was damaged. Make sure all of the O2's wire isn't press against the body of the car. If it is clear and look okay, it is definitely a bad sensor during the removal or during the install. The sensors are expensive to replace so make sure you check out everything.
Good luck.
Thomas
To Oxygen sensor issues after header install????
